s&b vs af1
Old Sep 19, 2007 | 11:28 AM
jcfx4king's Avatar
s&b vs af1
I am trying to decide which intake to get. At first i was going to go with the 3in af1 for my 5.4 2006 scab, but i've heard good things on here about the s&b. Now i can't decide. I want the 3in because i don't want to run into probs with a lean and have to get tunes. does the s&b need tunes and cause a lean? thanx guys, i would also like to hear if anyone is running aftermarket exhaust with it.
Old Sep 19, 2007 | 11:38 AM
MGDfan's Avatar
Originally Posted by jcfx4king
does the s&b need tunes ...?
Im most cases, yes.
Folks who tell you 'no', simply haven't measured this, so they can't say that with any certainty.
Old Sep 19, 2007 | 11:54 AM
05supercrew's Avatar
Every truck is different so if you start changing intake and exhaust you can alter your a/f. I have the S&B, Edge and Magnaflow si/so and love the set up.
Old Sep 19, 2007 | 12:13 PM
MercedesTech's Avatar
The s&b def. looks real nice. I was really wanting one until hearing you need to custom tune your truck around it. If you run the S&B with the Edge tunes, will it work well? Or are you better off calling Troyer? Hows your set-up workin out for oyu supercrew? you have anything to measure you a/f ratio? Anyone else running S&B intake ?
Old Sep 19, 2007 | 12:19 PM
I havent measured the a/f yet but the set up works great.
Old Sep 19, 2007 | 04:31 PM
Man that looks SWEET. Thanks Supercrew. You have a damn nice ride. I was looking in your gallery, I saw that Pioneer D-3 unit. You install yourself? How complex and is that "back up camera" capable? (sorry, just a bit off topic)
Old Sep 19, 2007 | 04:49 PM
I had a place install it with the by-pass switch. I havent picked up a camera yet. The unit it self is great. Definitly recommend it. Thanks on the complement.
Old Sep 19, 2007 | 09:15 PM
boomer08's Avatar
Hey jcfx4king give me an email about the S&B Intake. I tried to email you but you don't accept email messages.
Old Sep 19, 2007 | 09:35 PM
SteelTownStang's Avatar
Boomer... What's the secret? I'm about ready to purchase the S&B as well. Thanks.
Old Sep 19, 2007 | 09:37 PM
JeremyGSU's Avatar
HHMM. Interesting topic. If you're planning on going with a custom tune anyway and you can correct the A/F from the S&B then I guess the question is the AF1 worth the extra $75 over the S & B. I've been leaning towards the S & B myself.
Even if it nets another 3hp, is it worth $75 for that?
Old Sep 19, 2007 | 09:42 PM
MGDfan's Avatar
It's not just about peak power - it's about area under the curve.
Old Sep 19, 2007 | 09:51 PM
JeremyGSU's Avatar
I understand. Is AF1 power overall under the curve THAT much better than S & B's? Have both ever been tested with corrective tuning?
Old Sep 19, 2007 | 09:57 PM
MGDfan's Avatar
Yup. You'd need to call TP for that data though.
They've got MAF transfer functions already written for both and will support either one - and several others.
You can only do that if you do a ton of testing.
bubba
Old Sep 19, 2007 | 10:34 PM
JeremyGSU's Avatar
MGDfan,
If I did end up going with an AF1 3.5" intake but had it tuned by someone other than Troyer, is the A/F the only thing you have to dial in correctly?
Old Sep 19, 2007 | 10:52 PM
MGDfan's Avatar
MGDfan,
Pretty much. For example, if you get tuning for a 3" AF1, then decide to upgrade the tube to a 3.5", the only real change that is made is the MAF TF gets replaced with the correct one for the new intake.
Note that this I possible with a mail-order tune only if the variables are known
