to dump before or after the axel
Old Sep 13, 2007 | 08:40 PM
gamer565's Avatar
i think about cutting my dual off and dump them before or just little after the axel. would there be any noticeable difference between the two?
Old Sep 13, 2007 | 09:29 PM
built54's Avatar
not really that noticeable... Id do it right before.
Old Sep 13, 2007 | 09:31 PM
BLUE20004X4's Avatar
You'll hear it better the closer to the cab you go, dump in front
Old Sep 14, 2007 | 01:58 AM
gamer565's Avatar
thats wat im think, plus it would be easier to do
Old Sep 14, 2007 | 02:19 AM
only adverse effect is some people believe that the hot exhaust gases will shorten the life of your axle, and rear end.
BTW mines in front of the axle, about 2' so i think there is plenty of room to disperse the hot gas into the air flowing under the truck.
Old Sep 14, 2007 | 05:20 PM
dly97's Avatar
Mine is dumped before the axle. I am about to get it extended after the axle. The Dynomax Bullet still sounds great, but the drone has really picked up the last couple of months. People in the back seat have a hard time hearing anybody in the front. I might run it out behind the rear tire, haven't decided yet.
Old Sep 15, 2007 | 03:10 PM
gamer565's Avatar
i think of cutting it right before the pipes start going up and over the axel and just do that or cut them complety off and get like a turn dow tip or just some 45degree pipe.
Old Sep 15, 2007 | 04:49 PM
Kevin24's Avatar
That's what i did.I just cut them off right after the muffler.It added a considerable amount of sound after.You will get more drone in the cab though.
Old Sep 15, 2007 | 06:57 PM
gamer565's Avatar
true fully i like a little droning, just insurer's me that its really loud on the outside
Old Sep 15, 2007 | 07:25 PM
MmmBuckles's Avatar
thats exactly where i cut mine. but i dont have turn downs, i think that might be the reason why my pinion seal keeps leaking though(exhaust melting it)
Old Sep 15, 2007 | 08:53 PM
4wd150's Avatar
how much would dumping my exhaust before axle cost me about?
Old Sep 16, 2007 | 12:03 AM
gamer565's Avatar
well if u all ready have the exhaust system ran and a sawsaw then it would cost about half a hours work lol
Old Sep 16, 2007 | 03:39 PM
4wd150's Avatar
yea, but i just read this thread again and it says like the hot exhaust on the axle isnt good, and will shorten the life. idk if this is true or not
Old Sep 16, 2007 | 04:07 PM
Kevin24's Avatar
I myself don't see a problem with heat unless you were close to the rear end.Also IMO it is going to take alot of heat to mess up the rear end.I think your worrying to much.
Old Sep 16, 2007 | 04:31 PM
4wd150's Avatar
yea, thanks for your input
