Magnaflow 16614 Does not fit.
Old Aug 20, 2007 | 05:33 PM
z-u-later's Avatar
Well the part # 16614 by magnaflow that I ordered does NOT bolt right up. I found this out AFTER i dropped the stock exhaust. The tailpipes extend out about 10" past the bumper.
So I call magnaflow & there response was that the exhaust is NOT cut to fit the Short bed supercrew 04 F150 the wording is a misprint on there web site. Other then cutting & bending & sacrificing the design of it , the stock one gets bolted back on & the magnaflow gets shipped back. What a PIA.
Old Aug 20, 2007 | 07:18 PM
2001Screw4x4's Avatar
Have you purchased ANYTHING for your truck that you have not complained about or had problems with?
Old Aug 20, 2007 | 08:50 PM
BlackDawg's Avatar
Does the mid pipe need cut? I can tell you that I'd probably never buy a "packaged" exhaust again. I suggest buying the exact muffler and tip you want then find a good custom exhaust shop and tell them where you want it to exit and sit and read a magazine for the 1/2 hour to 45 minutes it takes them to do it. I already changed my whole exhaust from the 16612 and did it custom for about $100 LESS than just the 16612, including new muff/tip/install/pipe bending, etc. It fits better, you could do chin ups from it and it's exactly how I want it. Good luck.
Old Aug 20, 2007 | 09:37 PM
Delta17's Avatar
quick question - i'm just looking to order the 14" magnaflow muffler, not a whole set up.
is the part number 16614 applicable to a 98 F150 with the 4.6? I always get confused as to which part number i would want when it comes to ordering. Thanks for your help guys and sorry it didnt work out for you z - u later!
THanks again,
John
Old Aug 20, 2007 | 09:41 PM
z-u-later's Avatar
This forum is filled with knowledge, oh yeah and rude commenting individuals. Just want to find out if anyone else had issues w/mag cat backs .....
Old Aug 21, 2007 | 08:53 AM
05supercrew's Avatar
This is my 3rd Magnaflow cat back and had zero problems.
Old Aug 21, 2007 | 01:05 PM
z-u-later's Avatar
I see yours is a side exit single pipe, I ordered the dual rear exit thanks for the reply, I presume after 3 systems your satisfied with there exhaust !
Again Thanx
Old Aug 21, 2007 | 01:20 PM
Again Thanx
Never had a problem, they always fit perfect. Thats why I keep getting Magnaflow.
Old Aug 21, 2007 | 02:32 PM
curio's Avatar
What part number should you have got instead?
Old Aug 21, 2007 | 04:26 PM
05RedFX4's Avatar
The 16614 was not designed to fit an 04, they are for 04.5 and up the 04's require a different part #. try getting a #15834, it's a dual rear exit designed just for the 04's built prior to may 31 04
Old Aug 21, 2007 | 04:40 PM
Yes, always check the build year before ordering.
Old Aug 21, 2007 | 04:49 PM
bowlergt's Avatar
Cut the tailpipes? You have to bolt on the tips anyways? Is it that big of deal? I just put a magnaflow catback on my 2000 and I had to cut about a foot off the midpipe other then that it fits like a glove
Old Aug 22, 2007 | 02:33 AM
This forum is filled with knowledge, oh yeah and a**h&*es like you. Just want to find out if anyone else had issues w/mag cat backs .....
Ouch.
Seems that you brought this problem on yourself by purchasing something for a different model year.
Old Aug 22, 2007 | 05:17 PM
Damestic89's Avatar
Wierd, I ordered the 16614 and it looks perfect. It's for a 2006 Screw with 5.5' bed.
Old Aug 22, 2007 | 06:43 PM
z-u-later's Avatar
Well the vendor is shipping another system I'll have it at the end of the day, the 1st system could have been packed incorrectly, I will try this install again towmorrow, thats if my 20 month old son naps long enough for me to finish the job !
One way or another its gioing on ..
Thanks for all your help here on the forum, you people have been great...
