1999 Rear diff cover torque specs
Old Aug 5, 2007 | 10:20 AM
Mattyb150's Avatar
I got a 1999 f150 XLT 4X4 and was wondering if anyone had the torque specs for the rear differential cover?
Old Aug 5, 2007 | 04:44 PM
dondiesel444's Avatar
tight but not too tight
I just changed my gear oil in the rear end and just tighten the bolts up by feel, I've actually never torqued rear cover bolts, just make em tight with a 3/8" rachet, no need to really crank them down suoer tight....
Old Aug 5, 2007 | 05:10 PM
built54's Avatar
just get them snug
Old Aug 5, 2007 | 05:35 PM
Kevin24's Avatar
X3^^^^^^^^^^^
I think the specs are like 30-35ft lbs but i would just snug them
Old Aug 6, 2007 | 02:26 AM
NYfordguy's Avatar
x4 ^^^ differentials aren't really "high pressure" either, just gears sloshing around in heavy oil.
Old Aug 6, 2007 | 02:48 AM
JohnG6's Avatar
The cover is stamped steel and will warp if you're too heavy on the wrench. If in doubt, it's better to fail on the loose side and clean up a small seep later on than to crank it down too tight and end up having to buy a new cover.
Also, if you're using silicone gasket sealer, be sure to give the sealer time to cure before filling the diff, otherwise you'll end up with a leak.
Good luck!
