True Duals fail stock cat conv?
Old Jun 30, 2007 | 05:35 PM
Foxacrombie's Avatar
Howdy,
I have been running true duals with stock cats since this winter. In April I had to replace the main cat with the o2 sensor. I started my truck up today and it sounds like the cat is failing again. Neither time, have I got a CEL, and i'm getting nervous. I talked to a couple muffler shops, and they all pretty much said that I need hi-flow cats to run true duals. They said I probably don't have any backpressure. Is this true? Anybody with 5.4L, true duals, and stock cats have the same problem? I am going to put a maggie on to replace the stock cat, but I'm nervous something else is wrong with the truck to be failing cats like that? Any advice/comments/suggestions? Thanks,
Mike
Old Jun 30, 2007 | 05:49 PM
Kevin24's Avatar
I don't see how having true duels will hurt the stock cats.
I have had true duels on mine for 1 1/2 years now with no problems.
Old Jun 30, 2007 | 05:58 PM
phil6608's Avatar
Originally Posted by Foxacrombie
Howdy,
Mike
You would have more back pressure with the stock cats and less with high flows!
Phil
Old Jun 30, 2007 | 06:05 PM
Kevin24's Avatar
Phil
Right!!!!
how does the exhaust shop know the cats are bad??
Old Jun 30, 2007 | 06:18 PM
It's official... they were just trying to make a sale on some maggies. I just knocked on the Cat and didn't hear any rattling... then i fire up the truck and got back under with a mirror. I have a hole the size of a quarter on top of the pipe, right after the cat. It was shooting exhaust up into the heat shield. Unbelievable! I'm going to have a nice chat with management on Monday morning.
Old Jun 30, 2007 | 06:38 PM
Kevin24's Avatar
How did it get a big hole in the pipe?rusted?
Old Jun 30, 2007 | 06:59 PM
phil6608's Avatar
Ya,that will definitely make it sound like somethings wrong!
Glad you found it.
Old Jul 1, 2007 | 04:25 PM
openclasspro#11's Avatar
Phil
bull****-4 years 78 k miles on my duals- no issues whatsoever-btw- i checked the pack pressure in my cats under load in 2nd gear at 5500 rpms 1.5 psi backpressure on each bank=[hardley anthing for stock cats]
Old Jul 1, 2007 | 04:42 PM
phil6608's Avatar
You should try that test with some high flows and see what you get!
It just may be way LESS,,,,lol.
Phil
Old Jul 3, 2007 | 06:43 AM
phil
Phil
phil=i'm just healing from a motocross injury from mother's day-to the tune of over $150 k and counting- needless to say i gor brain contusions-i dug up all my vehicle notes- with the in cab test using a magna helic gauge:-it was a combined 1.5" back presuure- roughly .75 a side- hardly anything fo a daily street driving van but i will be going to magnaflow hi-flows for sound and will post results- my memeory still is in libo at times- sorry for typing wrong numbers-phil
Old Jul 3, 2007 | 06:46 AM
phil
Phil
i can't imagine waht a 6k lb supercrew runs like at 11.68-my 89 ta gn motor turbo v-6 runs 11.0@121 -would love to have that performance in a sreeet sleeper ford tuck
