magnaflow install
Old Jun 21, 2007 | 08:12 PM
tylerN's Avatar
magnaflow install
just bought the maganflow cat backs on performance peddler for half the suggested retail. what all is needed to install the duals? what tools are needed? how ong does it take?
Old Jun 22, 2007 | 04:30 PM
torkum's Avatar
Welder, jackstands, hangers, and clamps.
Old Jun 22, 2007 | 06:34 PM
tylerN's Avatar
is a welder needed
Old Jun 23, 2007 | 01:54 PM
jjmIII's Avatar
Originally Posted by tylerN
is a welder needed
No, but I think it is nicer welded up.
I pd a shop $60 to install my last cat-back.
It's kinda worth it. They weld it and install it just right.
The only place they bolted it was to the cat.
Old Jun 23, 2007 | 11:12 PM
Arca_ex's Avatar
Well I didn't weld mine, all you need is a metric socket set and you're good to go. I didn't even have to put my truck up on jack stands or anything and the clamps are doing perfectly fine.
Old Jun 23, 2007 | 11:19 PM
Zam:Karmen's Avatar
I clamped my 16612. The first day, I had leaks and didn't like how it turned out.
The next day, I disassembled the system and reinstalled it, taking more care to orient the muffler they way I wanted it and the tail pipe the way I wanted it. I began bolting the clamps from the front and working my way to the back.
Along the way, I overtightened a clamp and broke a bolt (*doh!*) I used the remaining clamp and hooked up everything except the tail piece. I left that "floating" and then drove down to a local muffler shop. Once we had the tail pipe positioned the way I wanted, it, he welded it together.
So aside from that mishap, all went well, but I think welding the tail piece would be a good idea since that's quite a bit of weight for a clamp to hold without sagging.
Old Jun 24, 2007 | 12:14 AM
ws6_guyscrew's Avatar
yeah pretty much sockets & some wrenches & you can install your own catback. Welding is more secure & a stronger hold though. Removal for the stock exhaust can be very fun if you have a sawzall haha
