Exhaust sound
Old Jun 3, 2007 | 07:04 PM
Faster150's Avatar
Originally Posted by built54
nope, i dont want to spend $500 in gas lol. What do you run in the 1/4? put some 33x20's on your truck and we will race
haha gas is 2.89 here!
and in the 1/4 mile no tellin the track here sux. everyone who runs at it goes to a better track like at San antonion houston or ennis and cuts about .8 seconds off of it. but about 3 years ago with a superchip intake and a weld in muffler. i pulled a 16.2@79mph
Old Jun 3, 2007 | 07:21 PM
built54's Avatar
not bad... You have a huge weight advantage on me too. Plus you have a lot smaller and lighter tires, and your not lifted. gas is 3.50 here. How does the track cause you to loose almost a second?
Old Jun 3, 2007 | 07:59 PM
Faster150's Avatar
poor track prep. narrow lanes uneven lanes.. speed bumps.. its horrible. some many people crash out there its a shock its not been closed down.
ohh i check my heads are D20A heads. so they are D heads.
Old Jun 3, 2007 | 09:00 PM
Kevin24's Avatar
Faster,So whats the deal on those heads ###s?
and your truck is reg cab short box?
Old Jun 3, 2007 | 10:01 PM
Veteran: Army
he's got a supercab short bed
it's a small private track they only "prep" the surface for the outlaw 10.5 cars but those guys have traction issues constantly but non the less it's a fun track for weekends with a street driven vehicle. a lot of fast N furious wanna be's go up there and it's easy pickins on test N tune night nothing better than watching a big ol' truck woop up on a fart canned civic with no hood
Old Jun 3, 2007 | 10:16 PM
built54's Avatar
thats what its all about
Old Jun 3, 2007 | 11:36 PM
Faster150's Avatar
the D heads are suppose to be some kinda special from ford. bigger valves and larger intake ports.
Old Jun 4, 2007 | 12:18 AM
jbrew's Avatar
Is there a special part # on the heads so you can tell if you have the "D" heads ?
Old Jun 4, 2007 | 06:55 AM
built54's Avatar
what had those heads? Why would the make these?
Old Jun 4, 2007 | 07:27 AM
Kevin24's Avatar
I just don't see why ford would put a special set of heads on a regular truck Whatever the case it seems to be running good!!
Old Jun 4, 2007 | 11:27 AM
Faster150's Avatar
i read somewhere on SHM site about the D series heads that ford put on the non PI windsor motors. that had larger intake ported and larger intake valves good for about 20-25 more fwhp. it could just be a rumor. but might be true since my little 4.6 has always run like a bat outa hell. for it coming with 215crank hp from factory and im puttin down around 250-255rwhp... thats quite impressive for not touching the long block at all. hell even neal port matched his heads on his first motor.
Old Jun 4, 2007 | 06:15 PM
jbrew's Avatar
Yeah , I was thinking I might have them - Doing the math , I can't have more than 300 FWHP in my NPI 5.4L . All I really have for mods is the maggy cat back and an intake w/polished TB and elbow . Yet my 19lb injectors can't seem to keep up with my air comming in and boggs. It still goes pretty good , it's got much more wanting to cut loose , feels like
Instead it just boooggggggs ....
Frickin thing.
Well, I 'm removing my rear cats right now - mann are those things wasted - I might gut the fronts while I'm at it. Hope I don't throw any codes..
Old Jun 4, 2007 | 11:12 PM
built54's Avatar
when I had only a tune, intake and exhaust, i had 186 at the wheels, so i doubt you have 300 at the flywheel
Old Jun 5, 2007 | 12:28 AM
jbrew's Avatar
Yeah , that's what I'm thinking - My injectors should be putting out enough fuel , but then again I might need a tune as well.
Okay , I removed my rear cats and left the fronts alone and hehehe mannn she sounds bad a$$ now and it's not bogging nearly as much - I love the sound
I got about 5 miles and the check engine light came on - Dangit! I'll prolly need to do what you did Joey and eliminate all the stock cats and put a magnaflow high flow on each side.
Old Jun 5, 2007 | 06:53 AM
built54's Avatar
yep that would be your best bet
