Exhaust Pipes. Do dia. matter???
Changing the piping diameter will shift the rpm of the torque peak. The rule of thumb is that a larger diameter will shift the torque peak to a higher rpm. It will also reduce backpressure. Optimizing your torque curve for to match your driving style will improve your mpg and also help your overall acceleration.
Stay with the 2-1/2" and exit with a 3 in tip. Any larger and it will get "blapppy" you know what I mean.
I have an '03 F-150 with a flowmaster 430402 chevy application (89-350) 3inch in dual 2-1/2 out to 12 inch X 3inch stainless tips slant cut.
I get compliments all the time on the sound. Better a compliment than a complaint.
I made a run down to Houston last weekend and once your over 75 (2000 RPM) the sound dies down until you hit 95 (2400 RPM) then it comes back.
Thats running P-265-18's on 3.55 gears, yep 2k at 75 MPH and plenty of pedal left
And believe it or not but with Mikes 1750 programmer I got from him in '03 and the program I asked that he put in on the stock (enhanced stock Mike calls it) program I was getting just under 19MPG a gallon at those speeds.
If I stay at the speed limit it will get over 20 MPG.
Of course the city ratings suck because I hate driving with everyone else.
See 'ya
See 'ya
