What Cats can i cut off.
Old Apr 11, 2007 | 05:35 PM
Truedisturbance's Avatar
Ive been hearing people talk about cutting the pre cats off and they dont throw codes. can somebody please tell me which cats are my pre cats. thanks in advance.
Old Apr 11, 2007 | 05:47 PM
what year do you have?
And its called Gutting
Old Apr 11, 2007 | 05:51 PM
Old Apr 11, 2007 | 05:58 PM
You can gut the first cat out of each side. Also known as the pre cat. Its at a little bit of an angle compared to the other one. Remove the whole Y pipe/cats assy right off the exaust manifolds, and do whatever you can to break everything out of the first cat housing. I cut a small window in the side of mine after removing the heat sheilding.
-Patrick
Old Apr 11, 2007 | 07:26 PM
ok but i have one question why couldnt you just cut it off it seems like it would do the same thing.
Old Apr 11, 2007 | 07:28 PM
Jordan not Mike's Avatar
You can cut it off and repace it with pipe.
You can gut it.
You can gut it then run a pipe thru it.
Some states have visual smog inspections. If they see items are missing, you fail. Gutting it (or running a pipe thru it) makes it look like it's still there.
Old Apr 11, 2007 | 07:44 PM
ok thanks
