Magnaflow tip... is this right?
Old Dec 3, 2006 | 05:11 PM
houlster's Avatar
I just put on my Maggy cat-back on an '01 Expy and this is what the tip looks like:
You can see they inner tube extends almost to the end of the tip. Is this normal? It looks pretty crappy as is. I would expect the tip to be welded to the end of the tube, not around it.
--Dan
Old Dec 3, 2006 | 05:21 PM
built54's Avatar
That is how my magnaflow kit was too... For as much as it cost, i would think it would have been done better than that... Does your tip point more torwards the front than the back too?
Old Dec 3, 2006 | 07:57 PM
houlster's Avatar
No, it's pretty much straight out to the side. I do think it could stick out a little further though, but some re-adjusting might be enough.
--Dan
Old Dec 3, 2006 | 08:04 PM
Redsoxfan's Avatar
Nothing a sawzall wont fix in about 5 mins. Just cut it shorter and youre golden.
Old Dec 3, 2006 | 10:04 PM
houlster's Avatar
?? Well, I suppose it could be that easy, but only if I wanted to cut through the tip as well. Otherwise, it'll take a sawzall, grinder, welder, maybe a flap wheel and probably a couple hours at least.
--Dan
Old Dec 3, 2006 | 10:06 PM
built54's Avatar
yeah cutting that tip off and rewelding it wouldnt be worth it to me... Once carbon builds up you wont even notice it.
