MAG16614 Help and Coupon Codes
Old Dec 11, 2006 | 02:51 PM
  #31
MagnaFlow_Rep's Avatar
Former Sponsor
Not for the 2004. Its different. If its an Extended Cab/Short Bed or Long Bed.
Then the part # would be a 15821 SI/SO, DUAL SPLIT REAR EXIT Part # 15834 and Dual Same Side Exit in front of rear tire is 15827.
Old Dec 11, 2006 | 03:32 PM
  #32
fordsoldier's Avatar
15821 must be for the haritage. The new body style is 16614
Old Dec 12, 2006 | 03:16 PM
  #33
Kasick's Avatar
i have the new body style.... '04 1/2
Old Dec 12, 2006 | 09:08 PM
  #34
Ford1394's Avatar
Well the 16612 will fit my 07 F150 Super Cab 5.5 ft bed right cause I ordered it already..
Old Dec 12, 2006 | 10:40 PM
  #35
crashtheline's Avatar
Kasick, the 16614 is the single in dual rear exit...i have an 07 and just finished putting it on, WHAT a pain the ***! If you do it send me an email...you WILL need pictures of the install haha. I'm also making a thread when i get the pics.
Old Dec 31, 2006 | 12:15 PM
  #36
gilsnuxs's Avatar
This ? is for MagnaFlowRep:
Will 16614 fit on 06 supercab with a 6.5' bed. I've read several dozen post but I havent seen a definite answer. Your help is greatly appreciated.
Old Dec 31, 2006 | 12:17 PM
  #37
yes it will fit, I have an 05 supercab with 6.5bed. there is no difference between the two as far as fitment
Old Jan 2, 2007 | 01:27 PM
  #38
gilsnuxs's Avatar
Do you have any pics that I may see. I am about to order the exhaust (16614) and just want to make sure I like the fitment
Old Jan 2, 2007 | 01:48 PM
  #39
Tical84's Avatar
The Standard Cab/Short Bed would be part # 16613
Can I play too? I emailed Magnaflow but they said there was nothing specific for my truck, I'd have to buy it for one (forget which one now) and cut it.
I have a regular cab, long box. si/so or si/do please.
Old Jan 2, 2007 | 01:56 PM
  #40
sure no problem here is one for you, let me know if you need any more.
Old Jan 2, 2007 | 02:05 PM
  #41
gilsnuxs's Avatar
I would like to see pics of the underside if you have any. Also, did you have to modify anything? Everyone I speak to at magnaflow says that I will have to entend the intermediete pipe, but people on here seem to say it will fit. I just dont want to buy it and have to butcher it up to make it fit.
Edit: Are the tips clamp on or welded on?
Old Jan 2, 2007 | 02:24 PM
  #42
one from the back
the underside.
the only modification was I had my buddy weld it all up at his exhaust shop and install new rear hangers. her is a pic of the hanger. I didnt want any leaks plus I know it is rock solid now its welded up.
using all the factory exhaust supports.
Old Jan 2, 2007 | 02:28 PM
  #43
gilsnuxs's Avatar
one from the back
the underside.
Thanks, appreciate the pics. I am going to weld everything up as well. Dont really want to rely on the clamps, plus this gives me an exucse to get the stainless conversion kit for my mig welder.
Old Jan 2, 2007 | 02:33 PM
  #44
glad I could help post a pic or two when you get it done.
Old Jan 2, 2007 | 02:38 PM
  #45
gilsnuxs's Avatar
will do.
