gutted cats and hi-flows?
Old Nov 5, 2006 | 02:00 AM
DeathMetalTruck's Avatar
Hey anyone here gut their pre-cats and install rear magnaflow hi-flow cats? Results? Emissions problems? I live in CT and have a diagnostic test as well as a visual test so I was thinking this would be the closest thing I'd be able to get away with...cause if I ditch the precats entirely I won't pass a visual test.
Plus I'm also wondering if installing the magnaflow hi-flows are really worth it. Do they make much of a difference? or should I just gut my precats and leave the original rear cats?
Old Nov 5, 2006 | 04:01 PM
also I live up north and it gets cold....obviously and supposedly thats what the pre-cats are for...for cold start up...so will getting gutting them not let me pass emissions?
Old Nov 5, 2006 | 10:58 PM
ws6_guyscrew's Avatar
any cat modification such as gutting will not pass emissions, high flow cats will pass though since they are a replacment, but idk about the pre-cats, I know Patrick gutted his 4.6Ls pre-cats and gained a little power but dont know if it will pass a test.
I could do anything, I have NO emissions though I will act as if I do, I dont wanna pollute.
Old Nov 6, 2006 | 05:58 PM
5.4TritonPower's Avatar
Will gutting the precats and adding aftermarket rear cats trigger the check engine light?
Old Nov 6, 2006 | 06:28 PM
nope, as long as there is no O2 sensors, and i'm pretty sure the pre-cats dont have them
Old Nov 6, 2006 | 06:53 PM
Hey thanks. That's what I was hoping for
Old Nov 6, 2006 | 07:36 PM
Jordan not Mike's Avatar
This is exactly what I did, CA has the sniffer and the visual.
The pre-cats look like they are there, but are in fact empty.
I've got Magnaflow high-flows in the back.
Passed the sniffer, no problem.
No codes.
And I've got a lot of mods.
You won't throw a code.
IMHO I suggest that you don't let your engine/cats cool-down prior to the smog test, as the pre-cats are there to heat up faster until the main cats are hot enough to function properly. In other words, go at a slow time so that you aren't waiting in line.
Old Nov 6, 2006 | 08:00 PM
Zaairman's Avatar
Why not just gut your cats all together? Don't remove them permanently, just empty them out... Not that I'm planning on doing this soon...
Old Nov 6, 2006 | 09:10 PM
yeah if you do not have emissions just gut them cats out or just run high flows.
Old Nov 6, 2006 | 09:41 PM
Zaairman's Avatar
Missouri does a visual/safety check in most areas, and in the city like where my truck is registered, they must pass a sniffer, however since mine is newer, it only has to pass a diagnostic emissions test. No CEL= I pass.
Old Nov 7, 2006 | 09:28 PM
Well thanks for all the opinions and advice....if i didnt have emissions id be running long tubes and probably no cats or hi-flows, but that aint gonna happen. So maybe ill gut the pre-cats and go hi-flows, but i still got thinking to do. Next in line for me is a tuner.
Old Nov 7, 2006 | 09:39 PM
Zaairman's Avatar
Why not gut all of your cats and then see if it will pass emissions? If it doesn't, then add the high-flows.
Old Nov 8, 2006 | 03:34 PM
jbravo316's Avatar
My exhaust guy just removed all of the factory cats and replaced them with 2 metallic substrate converters. They don't even look like converters at all. They look more like 2 bulges in the exhaust pipe than anything.
