Magnaflow catback for 6.5' Screw?
Magnaflow doesn't make a catback SI/DO for a SCREW with 6.5' bed...anyone have experience with splicing in a section between the Y-pipe and muffler to make up the difference?
Beytill,
So just to make sure I understood you correctly, you installed a magnaflow catback on a 6.5' Supercrew (150" Wheel Base), not a 5.5' Supercrew (139" Wheel Base)? Did the factory hangers and y-pipe connections line up Ok? When I called Magnaflow they said that did offer any systems for 6.5' bed and that they couldn't guarrantee that a 5.5' system would work. Please post pictures if you can.
Thanks, I truly appreciate the response ~ I didn't want to spend the $$ just figure out that I needed abunch of custom exhaust work on top of it....
flyfish_addict
flyfish_addict
Shouldn't be a problem to add extra 2.5" pipe before the aftermarket exhaust system, or extra 3" pipe to the aftermarket system.
