fix for loud intake?
Does anyone know if sound/heat insulator wrap will fix the noise from the aftermarket intakes?
I used to own a Chevy that had an AFE intake and I dont remember it being this loud. In my new Ford, I installed the same brand intake. I noticed it was very loud at certain RPMs when the engine was loaded (it didnt make the noise in park). Last weekend, I added the Edge Evolution programmer and WOW!! It is very loud, and all the time now! I dont like it at all. If I cant fix it, I'm going back to stock intake.
I tried adding another pipe clamp at the stock airbox support bracket thinking it may be a vibration problem. It didnt help. I believe the noise is coming from the thin rubber boot that joins the molded plastic tube to the engine, but not sure.
Any info would be appreciated.
done!
I added a heat/sound insulator to my intake over the weekend.
I used heat/sound insulation I found on e-bay for $25 (after shipping) and used 3M spray adhesive 08090 to apply it. It doesnt look too bad, and it definitely knocked the edge off the drone. I can still hear it, but it's nowhere near as loud as it was.
Dang it! I have pictures to post but cant figure out how to post them. URL??
pics of the insulation
https://www.f150online.com/galleries....cfm?num=11933
Check it out! As I said, it definitely helped with the drone.
