True Dual Kits???
Old Jul 9, 2006 | 12:51 AM
nixRsix's Avatar
True Dual Kits???
Any exhuast companies make a true dual kit??? They all seem to be SI/DO.......is this because of a backpressue reason?
Do you lose any HP from doing a true dual w/ an x or h pipe???? wouldnt it perform a little better???
Old Jul 9, 2006 | 05:54 PM
nixRsix's Avatar
ttt
Old Jul 9, 2006 | 08:47 PM
GrandA&TPerform's Avatar
No need for "true duals"...and that would include removing Cats which is unlawful for the first 8yrs/80K miles....and your truck will not run as efficiently.
A High-flow/high performance muffler replacing the stocker with dual tailpipes or larger single will get you what you need performance-wise.
CLICK HERE TO SEE OUR SHOP TRUCK
Old Jul 10, 2006 | 01:23 AM
nixRsix's Avatar
I wanted to redo the whole exhuast, header into some hiflo cats(one on each side) and then into some magnaflows (true duals) Wouldnt it run ok, smog, back pressure, etc.....???
Old Jul 10, 2006 | 01:31 AM
daoust's Avatar
seems true to me
Old Jul 10, 2006 | 01:43 AM
nixRsix's Avatar
wouldnt i get a lil better hp this way as well...........
Old Jul 10, 2006 | 09:43 AM
s1037s's Avatar
the main problem is packaging and space limitations.yes you can have true duals made,but your fuel tank gets in the way on drivers side.you may notice A Little top end improvement but not much on these trucks
Old Jul 10, 2006 | 09:47 AM
You didn't say anything about headers in your original post. Sure you can do the system from motor back for "True Duals"...but, as pointed out above...they both have to run down the passenger side. My advice? Just do muffler back and you'll be fine.
Old Jul 13, 2006 | 01:58 AM
Jeeps&Fords's Avatar
Banned for Use of Multiple Usernames
Why can't you have cats with true duals?
Old Jul 13, 2006 | 11:07 AM
02XLT4X4's Avatar
You could leave the stock cats and cut into the stock y-pipe and go back from there if you were so inclined.
Old Jul 13, 2006 | 01:19 PM
I didn't say you couldn't....he just clarified from his original post/question wanting "true duals" to say he was talking about from motor-back with headers. That would involve removing the stock cats as any type of header will most likely not bolt up to the existing downpipes/cats.....It's against Federal Law to remove Catalytic Converters within the first 8 yrs/80K miles unless they are damaged. That's all I was saying.
Yeah...but it's a lot of extra $ for no more performance than a SI/DO muffler...
Old Jul 13, 2006 | 01:43 PM
Jordan not Mike's Avatar
You'll have to get a shop fab-up true duals, and they can be done with cats.
That's what I've got.
Long-tube headers eliminate the pre-cats only.
But the bigger issue is, IMHO:
True duals on a basically stock engines aren't really needed. A SI/DO muffler would be fine with no performance penalty.
You only need true duals if you are running a blower/turbo, IMHO.
Just my two cents
Old Jul 13, 2006 | 04:14 PM
openclasspro#11's Avatar
no better ?
i pull my 6500lb mx race trailer every weekend in the hills of pa- my part throttle tq and pulling power ios increased over the stock factory 3# setup in my van-my.02$-phil
Old Jul 13, 2006 | 07:56 PM
Openclasspro - I read about your setup and I plan to do the same. That is SWEET!
Old Jul 14, 2006 | 05:49 AM
DJR 17's Avatar
That's an awesome exhaust setup! You wouldn't happen to have a sound clip?
