"Tornado"...true or snake oil?
in certain applications, these things work, but only because of a design problem with the original intake tract that does not create the tumble effect the insert creates. not really meaning a design problem but maybe overlooked deficiency.'
The patent went through just ahead of my attempt to patent it
Complete snake oil ripoff, just like sh**fire plugs and all the rest....
About the Tornado Performance Booster, if anything it will restrict the airflow. It is probably just another cheaply made item to fall apart and gets sucked into your throttle body. I guess people are led to believe this product is going to give you some kind of supercharger like boost - but there is nothing to it, so it is not going to be able to create (generate) any kind of boost by a simple vacuum source alone. Just like a supercharger, you must have power in to get power out. The vacuum created by the engine's air intake system is not going to make the Tornado keep multiplying in rpm, which it must do, to inturn create any kind of boost (it must be under pressure - PSI). Plus it is so flimsy (thin sheet metal - if you can even call it that) that it would probably buckle once it starts to create a boost. As stupid as it may sound - technically you would get more power by simply blowing into the air intake system. Dont waste your money. Better off buying a K&N air filter &/or a cold air intake system if you must do something.
Tornado Air Management short video:
http://truckworldtv.tenmagazines.com...29&lid=&sid=88
Another good topic would be on the fuel line magnets ("Fuel Boss" & "Fuel Master"). I would'nt waste your money on them either because: If it sound too good to be true - it probably is! I would like to see both of these on the Discovery Channel tv show Myth Busters.
yah ive heard nothing but put them in the garbage posts
I was talking to a local guy i met out here at a car meet and his 04 v6 f150 (older body style) he bought one for his truck, and i seriously had to try hard not to laugh at him. he said he didnt notice much if any gain from it.
-Patrick
-Patrick
