Which Intake: TrueFlow or Fram Boost?
I have heard the advantages and disadvantages between TrueFlow Intakes vs. Fram Boost Intakes. Fram seems like a good intake like a regualr K&N intake except with a dry filter, but TrueFlow uses the facotry airbox, keeping mud/water off the foam filter, but you replace the intake tube.
Any experience with these two intake systems, which would be better?
Take a look at an AEM Brute force. it has a heat sheld that keeps most of the stuff off. It is also a dry filter. Also there is a K&N cover that you can get to put over the filter element and it kept water out (to some degree) from what I have read.
foam filters like trueflow have been used well in high particulate environments like hte desert for higher tolerance filtering
i would NOT pick fram. if their intakes are anything liek their oil filters they are a complete joke
Check the filteration on the Brute force its like 1 micron. They have a good web page with good info. I bought mine at autoanything.com and used a coupon. So I saved a few dollars. Was there any major power gain? Hard to say I don't have any dyno time to tell. Now if you go to the wed page for fram and AEM I think they have pdf of dyno runs. I used those for some comparison. However you need to take them with a gain of salt.
Originally Posted by 98Lariet4x4
Originally Posted by Jeeps&Fords
This is probably the worst mod you could have made. You are sucking hot underhood air. which is taking power away. Don't believe the people who say that underhood temps are just over ambient. I have been playing with the IAT monitor in my Evo II and when I had the end of my air box was open I had IATs as high as 150*. When I sealed the airbox again, the IATs dropped to within a couple degrees of ambient.
And having an open cone filter is better how?
theyre arent, period. the best all weather designs are volant and outlaw (which i have and recommend). im also a fan of the airtube + stock air box type setups
Then there's truly no point to an air tube, other than aesthitcs, right? If you have the stock air tube, and a stock airbor, then the motors getting ust as much air as with an air tube. These motors don't move enough air for it to make a difference. So here lies the real question: Is it better to have lower air flow and cooler IAT temps, or higher airflow and higher IAT temps? Anyone got a home dyno?
Like Socal said, Volant or Outlaw(never heard of them - have a link?). IceMan has a nice system too, and that is what I designed mine from.
Originally Posted by greg hazlett
JLT intake. Dyno results=30 hp and 50tq with the intake and the SCT Tuner.
I don't care what all the marketing hype says about the open intakes, I have NEVER seen one that could produce a HP increase that could be consistently replicated. Open intakes are worth nothing for mileage or performance.
Now, everyone that has one chime in and tell us about the big HP numbers you have and how your truck feels faster. It must be true, because it would be pretty stupid to spend $200+ on something that does nothing. Why don't you add a TB spacer while you are at it.
