Removing rear cats on L...can I do this? Tips?
Old Jun 7, 2006 | 10:06 PM
SuperLB51's Avatar
Ok guys...I am wanting to remove my rear cats (the big ones) from my Lightning....how can I cut the cats out without having to remove my midpipes? and instead of welding can I use silicone connectors with T-Bolts to connect the pipe in there? The silicone connections are rated to 450*F...
I would weld them but I cant seem to get the mid pipes off my headers...I removed both bolts used an entire bottle of WD-40 and I pulled and pulled and they wouldnt budge....That could of been due to the fact that i couldnt remove my cat back exhaust because I tightend the clapms so tight that I actually crushed the pipe in where the clamp was so I cant remove it now....
Tips on how to do this?
Old Jun 8, 2006 | 01:22 AM
SuperLB51's Avatar
or what about 3" wide band clamps?? and what should I use to cut the cats out? I have a dremel with a cutting wheel attachment...would that work? can the heat sheild over them be removed to gain more access?? thanks!
