Removing Cats?
Old Jan 23, 2006 | 11:25 PM
bigplayer6907's Avatar
Removing Cats?
Will removing the front 2 pre-cats and replacing them with a piece of pipe mess with the O2 sesors right in front of them. I was guessing that since the sesors arn't located on the cat itself it shouldn't be a problem. Is this right?
Old Jan 24, 2006 | 01:38 AM
TX-FX-4's Avatar
First I don't know if where you live if it is illegal. Also, I believe the system relies on backpressure/temperature created by the entire exhaust system. I think that by removing the Cats you could change that temperature/pressure.(maybe a tuner could help balance it all out) I know there are some heavy fines if they are removed in some states. There may be some High flow Cat's available. Good luck
Old Jan 24, 2006 | 12:50 PM
my truck has 4 cats currnetly. i was talking about taking out the front 2 to make it a little louder until i get some high flows to replace all of them.
Old Jan 24, 2006 | 12:52 PM
3valve's Avatar
I removed my back 2 cats. Runs fine.
Old Jan 24, 2006 | 09:07 PM
TX-FX-4's Avatar
Thanks, I'll look into that as well. Souns like a good option.
Old Jan 27, 2006 | 12:43 AM
Where are your O2 sensors located? I have an 01 screw and the sensors are in the middle of the back 2 cats.
Old Jan 27, 2006 | 11:33 PM
KickinBlue4x4's Avatar
Removing cats is a mistake. Loss of low end torque - I had them removed for 2 months, and then put hi-flows on... What a difference. Go with high-flows.
