Dual exhaust with glasspacks
Old Jan 9, 2006 | 06:25 PM
HackoDis's Avatar
I'm going with dual exhaust with glasspacks with a crossover. My truck has a 5.2L v8. The exhaust is going to come out under the back corners of the box. Can someone give me a honest answer as to what my exhaust will sound like.
Old Jan 9, 2006 | 07:05 PM
ian51279's Avatar
5.2L? You mean 5.4L. Personally I think it will way too loud, but if that's what you want then go for it. I like the sound of an 18" Magnaflow. Grumbles at idle and gets loud when I romp on the pedal.
Old Jan 9, 2006 | 07:07 PM
cpaggie_07's Avatar
Sound quality is a personal thing. I will tell you, however, that there are definitely better quality mufflers on the market. I went with a stainless steel muffler, and would suggest you do, too.
Old Jan 10, 2006 | 03:59 PM
HackoDis's Avatar
The pipe is going to be stock 2 1/2" or 2 3/4" pipe, now seeing how the exhaust is coming out under the back corners of the box. The exhuast should have a nice rumble. Once i get it done i'll post back what it sounds like.
Old Jan 10, 2006 | 10:44 PM
ian51279's Avatar
I wouldn't go bigger than 2.5". If you go to big you will lose backpressure, which means a loss on low end power.
Old Jan 10, 2006 | 10:49 PM
HackoDis's Avatar
Thanks for the reply guys. Can someone tell me what is a good glasspack brand ??
Old Jan 11, 2006 | 05:23 AM
openclasspro#11's Avatar
brand
i heard dynomax bullets[jegs,summit] on a dodge 5.9- sounded very good!-phil
Old Jan 12, 2006 | 11:20 AM
Silverfish's Avatar
Why ISN'T a bigger pipe always better?
Got this off the Magnaflow site:
MagnaFlow's Frequently Asked Questions
Question: Why ISN'T a bigger pipe always better?
Answer: Don't be fooled! Bigger is not better! Many people think that having the biggest diameter pipe is the best way to make power.
Not true. Due to a variety of factors, extensive testing is required. We've dyno'd extensively and our systems yield optimum power increases. Some manufacturers claim even higher horsepower numbers.
It is a fine line to reduce backpressure while maintaining good exhaust velocity. It is not about getting the biggest pipe, it is about getting a more efficient pipe diameter while maintaining exhaust velocity.
There has to be a balanced design to enhance the maximum engine output, exhaust gas velocity, and sound. For example, imagine blowing air through a straw (comparing it to a smaller diameter pipe). This would take time to release all the air from your mouth, and you would feel pressure in your mouth while doing so. Now imagine blowing air through a paper towel roll (comparing it to a larger diameter pipe). You will relieve all your air much faster and feel little or no air pressure in your mouth because of the larger capacity of the tube. This is why it is important to get the correct size piping in order to relieve backpressure while maintaining thermal efficiency.
Use the guide below when calculating pipe size for custom exhaust work. Keep in mind that the goal is to improve exhaust flow. In most cases, just changing the restrictive OEM muffler and replacing it with the same size straight-through, Wide Open Performance MagnaFlow muffler will do the job.
To reduce additional backpressure, the OEM exhaust tubing can be replaced with mandrel-bent tubing of the same size or one size up from the OEM. As a general rule, you can enlarge the pipe diameter of your OEM exhaust system by 1/4 to 1/2-inch to increase your horsepower. However, any additional increase in pipe diameter is likely to decrease your performance; specifically, low end torque.
MUFFLER INLET/OUTLET
ENGINE SIZE HORSEPOWER Single Exhaust Dual Exhaust
150-200 CID 100 to 150 2" to 2-1/4" 2"
200-250 CID 100 to 200 2-1/4" to 2-1/2" 2" to 2-1/4"
250-300 CID 150 to 250 2-1/2" to 3" 2" to 2-1/2"
300-350 CID 200 to 350 2-1/2" to 3" 2-1/4" to 2-1/2"
350-400 CID 250 to 550 3" to 4" 2-1/2" to 3"
Use as a general guide for engine size and performance
Old Jan 15, 2006 | 01:59 AM
HackoDis's Avatar
I'm gonna go with 2 1/2 inch tubing all the way through. It will give the engine that nice rumble. Does anyone have sound clips of a glasspaack exhaust ??
Old Jan 16, 2006 | 04:07 PM
djanimale's Avatar
Glasspack
I just installed a Thrush Magnum Glasspack ($30 at O'Reily's) this weekend. It sounds awesome. Nice rumble, sounds like a muscle car with a lower tone. I have not complaints whatsoever. it's 28" long so you will need to buy at least 10" of extra piping to make the difference. let me know if you have any questions.
Old Jan 16, 2006 | 04:13 PM
HackoDis's Avatar
I'm thinking of going for either 12 in or 24 in glasspacks. Now if i i turn around the glasspack so the air flows over the bumbs instead into them, will it make it louder ??
Old Jan 19, 2006 | 10:57 PM
countryboy05's Avatar
ive got 18" glasspacks with 2 1/2" stock pipe out to 5" tips out under the corners and mine are pretty dang loud on a 4.6L.
https://www.f150online.com/galleries/mygallery.cfm?gnum=7113
Old Jan 21, 2006 | 09:01 PM
jcp123's Avatar
I like to run the 'packs with one size smaller pipe coming out then coming in, it's an old rodder trick. For instance, on my Bronco, I plan on running 2.25" in and 2" out. Gives it a hell of a rumble.
Another idea I like is simply to cut the muffler out and stick a set of Harley-Davidson baffles into the pipe. Heard this on an '31 Ford with an Olds straight 8 once, had 8 pipes coming straight out of the engine about 14". Sounded fantastic.
Old Jan 23, 2006 | 02:22 AM
HackoDis's Avatar
Anyone have sound clips of a glasspack exhaust ?? Thanks everyone for the posts and tips.
Old Jan 29, 2006 | 01:55 AM
AlbertaXLT's Avatar
Here is a link to a thread that has a video and sound clip of glass packs. Hope this helps.
https://www.f150online.com/forums/sh...d.php?t=210074
