To pipe or not to pipe.
Old Jan 8, 2006 | 07:57 PM
The Real Mccloy's Avatar
Hey guys,
I just got my dads 1998 f-150 with a 5.4l, extended cab, and 4x4. I went to a muffler shop and for $340 canadian they will run some true duals with the factory cats in place with 14" glasspacks. I just can't decide if I should do it, worried it will be too loud and wake up the neighbors when I leave for work in the morning. But I have also always wanted to put pipes on a truck, this is my first truck with a V8 and being worthy of pipes. Any thoughts or ideas are appreciated.
Old Jan 8, 2006 | 08:00 PM
JJG052590's Avatar
Banned
If that was me I'd do it but i wouldn't have glass packs i'd just run true straight pipes right from the cats..
Old Jan 8, 2006 | 08:24 PM
Black Hawk's Avatar
Thats the exact same set up that I have on my 97 5.4. It sounds really good and theres not many other trucks running that setup around here. Im about to redo it thou and put a shorter glass pack on it. I wouldnt worry about wakin up neighbors just be a easy on it till you get away.
Old Jan 8, 2006 | 08:26 PM
JJG052590's Avatar
Banned
Yeah, If you're worried about your neighbors just don't drive it hard at all until your out of the neighborhood or whatever..
Old Jan 8, 2006 | 08:27 PM
Black Hawk's Avatar
And then the bad thing about running true duels without glass was i got sick of getting noise violations when i went to town
Old Jan 8, 2006 | 08:30 PM
JJG052590's Avatar
Banned
Can't you avoid it by not getting on it hard or is it really that loud?
Old Jan 8, 2006 | 09:35 PM
Brian 5.4's Avatar
I have a bolt-on cat-back exhaust on order, expecting it by Tuesday or Wednesday. I went ahead and pulled off the existing exhaust all the way up to the cats. It is now running on manifolds and cats-nothing else. Even this isn't very loud. With full tailpipes and mufflers it shouldn't be too loud like your afraid of. Thes 5.4 engines are just quieter than most. You should be fine. It will rumble pretty good, but is by no means obnoxious.
Old Jan 8, 2006 | 10:35 PM
hey,
Thanks guys for the quick replies. I am thinking of definately doing this to the truck, and I am glad that it won't be too loud with the glasspacks. I was just wondering if any of yours got too rappy once the glasspacks burnt out a bit? Thanks again.
Old Jan 8, 2006 | 10:46 PM
JJG052590's Avatar
Banned
Well from what I know glasspacks are pretty cheap so if they burn out buy new ones! best of luck to you!
Old Jan 9, 2006 | 07:54 PM
bigplayer6907's Avatar
the 4 cats quiet the truck down alot. try taking out the front 2 pre cats if you want it a little louder.
Old Jan 9, 2006 | 07:58 PM
JJG052590's Avatar
Banned
What do you put in place of the 2 pre cats?
Old Jan 9, 2006 | 10:18 PM
weld in a piece of pipe on each side
Old Jan 9, 2006 | 10:20 PM
my friend just had true duals put on his 5.4 exiting in front of the rear wheels and wasnt happy with how quiet it was so he went and got all 4 cats taken out. if u want loud exhaust...address the cats. they are very restrictive.
Old Jan 9, 2006 | 10:24 PM
JJG052590's Avatar
Banned
I might think about that.. thanks!
Old Jan 9, 2006 | 11:05 PM
Hey,
Ya I just don't want to mess around with any of the sensors. The guys at the muffler shop strongly suggested leaving both cats and all sensors right where they are. I am def gonna go for it when I get the truck, will let u know how it turns out.
thanks
