Another Exhaust question:
Old Dec 3, 2005 | 01:20 PM
Swampwalker3's Avatar
I searched, but I'm wanting to do something a little different than what I've found..
So, after a few members came over and made fun of my exhaust, I finally came to redoing them today. Went out and got a couple of mufflers to place onto the pipes once I rerouted them. Spent a little too much time trying to figure out how to branch one of the pipes over towards the driver side area but thanks to my Tranny/T-case/Drive shaft my efforts were futile, so decided to keep the straight pipes, since mufflers won't fit either way, and run them next to each other.
Now, I was wanting to dump the exhaust right before my axle but thanks to my lift (Suspension) I fear for my rear, so I took the two short pipes I had, and managed dumping the exhaust about midway (They line up with the U-joint) of the BKO. I'm sure It'll be loud, (It's dark and Im afraid of my neighbors) but is this set up problematic mechanical wise or should I just shoot the pipes out the back, but not exceeding the rear axle?
The pipes tuck next to the frame on the inside so unless I branch the exhaust down and then out, I can't shoot out before the tires, I imagine that'll be fine? When I imagined the idea though, it looked a bit funny..
Anyway, I need advice and I'm running 2 1/8 ID pipes.
Thanks,
Zane
