what size is the stock pipe
Old Jul 22, 2005 | 12:00 PM
noname05's Avatar
on an 05 exhaust, is it 2 1/2'' (f150 stx) I tryed the search and it never pulled anything up.
Old Jul 22, 2005 | 12:21 PM
Sooowee's Avatar
The stock exhaust pipe is 2.5"--at least on my FX4.
Old Jul 22, 2005 | 12:58 PM
noname05's Avatar
so then whats the point of changing the whole pipe setup if most places just give you a 2 1/2 in set up, but thanks man.
Old Jul 22, 2005 | 05:39 PM
Faster150's Avatar
stock piping on the 4.6L and 5.4L is 2.5" the pipe on the 4.2L is 2.25" and the diesels use 3"
Old Jul 22, 2005 | 06:34 PM
Regulator54's Avatar
Just make sure you clean up the factory Y-pipe where the two 2 1/2" pipes combine into one 2 1/2" pipe. Even the most popular after-market systems install after the Y-pipe and use 3" piping from there back. But guess what? That factory Y-pipe exits at 2 1/2" and no matter what you do after that, you still pass everything through that 2 1/2" hole first. Either go with a proper dual 2 1/2" inlet to 3" outlet Y-pipe or go dual 2 1/2" pipes into either dual mufflers or a double inlet single muffler. I chose the DI/SO setup myself.
