H or X pipe
Old Jun 6, 2005 | 04:51 PM
CEE21's Avatar
H or X pipe
Is one better than the other or are they the same or is it a matter of preference?
Old Jun 6, 2005 | 05:49 PM
racerf150man's Avatar
x i believe has more flow rates then an h since it does not have a 90 degree anywhere in it. correct me if im wrong but i think an X pipe has a little louder tone tho because an H pipe can have some of its sound waves enter the cross and cancle out. Their pretty close tho
Old Jun 9, 2005 | 04:03 PM
CEE21's Avatar
Do you mean pretty close as how they help with the power on the low end?
Old Jun 9, 2005 | 04:09 PM
yes they are basically the same powerwise.. the X might be a LITTLE better but i dont even kno if a dyno would pick up the fraction. i would have an X installed if it were up to me .. just for sound reasons
Old Jun 9, 2005 | 05:11 PM
max mitchell's Avatar
Quote 1- "Why is an "X" pipe better than an "H"? The reason an X-Pipe crossover works better than an H-pipe crossover isn't more flow because of volume, but more effective use of exhaust gas velocity. Exhaust gas (or air) has surface tension, and flows much like liquid would through the same pipe system. As the cylinders of each bank on a "V" style motor fire, they create a pulse in the system. The pulses will alternate back and forth from bank to bank as the motor runs. With multiple cylinders, such as a V-8, the eight cylinders alternately fire creates lots of pulses in the system. If you put your hand behind the tailpipe, it would feel like a constant flow of air, but what it really is a lot of singular pulses giving the impression of constant flow. The idea behind the H and X style crossover is to unite the two banks of cylinders for better exhaust gas scavenging. Instead of two separate banks of four cylinders doing their own work, the crossover uses the pulse created by a firing cylinder of one bank to create a vacuum in the other bank because of surface tension. When a cylinder of the other bank is ready to fire, instead of the piston having to force the exhaust gas out of the cylinder, the vacuum that was created by the other cylinder bank helps suck the exhaust gas out of the cylinder, hence the term "scavenging." Whenever you can reduce the load on an internal combustion engine, you are likely going to see performance and efficiency benefits. The difference between an H and X crossover is a smoother path for the exhaust gas to follow. Exhaust gas, like a liquid, will follow a path with the least amount of resistance. An H crossover has a path with two sharp 90-degree angles that are close together. An X crossover has a path with a much more gradual bend to allow the exhaust gases to continue their path back out to the ends of the tailpipes, rather then turning sideways for a short distance, then turn again to head out the tailpipes. Smooth flow with high velocity means more power by use of scavenging. Using an exhaust system with too large of piping diameter work against scavenging in the same way that running an exhaust with too small of tubing chokes the motor and forces it to work harder to expel the exhaust gases."
Quote 2- "For any performance exhaust system, some type of crossover connecting the two sides of a dual exhaust system is important because it acts to balance the two banks of the engine. The common H-style crossover is good at balancing sound pulses between the two halves, but does little to promote scavenging because the exhaust gases tend to follow the path of least resistance, which is straight through each pipe rather than taking the 90-degree turn through the H-pipe into the other half of the system. In an X-pipe system, however, where the two sides of the system intersect, the gasses have no choice but to intermingle as they pass through the junction. This promotes improved scavenging effects by smoothing out uneven exhaust pulses from the engine’s firing order. It also helps quiet down the exhaust, resulting in a mellower, less raspy tone. The faster acceleration of the gasses through an X-pipe causes them to flow in a linear fashion parallel to the walls of the tubing rather than tumbling. This “laminar” flowing gas is much quieter than tumbling gas, resulting in an exhaust tone up to 8 decibels quieter than a traditional H-pipe."
Old Jun 9, 2005 | 06:14 PM
les017's Avatar
that's EXACTLY what I was gonna say
Great post - thanks
Old Jun 9, 2005 | 11:28 PM
Regulator54's Avatar
Couldn't have said it better myself. Reminds me of the older cars with factory dual exhaust. No crossovers at all, just alternating puffs of exhaust vapour from the tailpipes at idle. Oh the good old days. One other option is the DI/DO or DI/SO mufflers. A few have built-in crossovers but most usually just let the exhaust gas mix around inside the muffler and race to get out the tailpipes. Saves a bit of cost by eliminating the X or H pipe.
