glas packer
Old May 16, 2005 | 06:52 PM
fordtough_k_w's Avatar
glas packer
i just bought a glasspack but i was wondering if it makes a difference on which way you put it on. i have it so the flow is going towards the tabs that stick up inside
does the other way make a difference
Old May 18, 2005 | 06:25 AM
MGDfan's Avatar
Refer to this data, kindly provided by:
Originally Posted by ONE04FX4
here is some good info on mufflers that i have went by for years and it has worked great for me and others.
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
BTW, my condolences on your decision to use glasspacks ;-))
Cheers
Old May 18, 2005 | 03:01 PM
sgauthier's Avatar
face them so that the flow goes over top of the tabs for less restriction. my buddies Bully Dog exhaust on his heavy duty also had the tabs inside the muffler and that is the way the supplier told us to face them
Old May 18, 2005 | 04:31 PM
what is cfm and is the higher better or what
Old May 19, 2005 | 07:11 AM
MGDfan's Avatar
CFM = cubic feet per minute. Higher is better. D'oh. ;-))
Y'know, you could have Googled for the answer instead of waiting for someone to tell you. I'll bet you don't use the Search feature here, either.
Interesting you didn't ask what 'wc' meant...
It's much easier to help those who are also most willing to help themselves...
Cheers
