Magnaflow & Droning...
Old May 1, 2005 | 10:37 PM
sranger's Avatar
Hello,
I installed the Magnaflow SISO 3" exhaust on my 2000 F150. After about a week, it developed a loud drone at about 1500-2000 rpm with the worst noise at 1800rpm. I checked and it is not leaking. Unfortunately, this rpm range translates to 55-65mph so it is especially loud on the highway going up hill at these speeds. It is most annoying at 65mph.
Anyway, I decided to re-mount the stock vibration dampener to see if it would help. I cut the old 2-1/2" clamp off flush with a band saw and welded on a new 3" clamp bracket. I had to also drill a new hole to match the 3" U bolt. I mounted the modified dampener about 1/2 way up the 3" pipe between the old tube and the muffler.
It certianly helped a lot with the droning noise. It is much less annoying now....
Thought you guys might want to know.....
Old May 2, 2005 | 01:41 AM
ucfperspicere's Avatar
I've had the same exhaust on for a couple months now and no problems with droning. But then we don't have too many hills here in Florida.
Old May 2, 2005 | 01:51 PM
thomasj's Avatar
I've notice the same thing on mine, climbing hills it is really noticable. I had thought about reinstalling the damper, but didn't know if that would help. I think I will give it a try before I start towing the camper this year.
