What if the muffler was off?
Old Feb 28, 2005 | 07:47 AM
RedneckFord's Avatar
If i cut out my flowmaster 40 series muffler and just made it straight pipe, how much louder might it be? I would leave the cats, but also wondering if there would be any big power sacrifices or engine problems without the muffler
thanks
phil
war eagle
Old Feb 28, 2005 | 10:09 PM
porky's Avatar
im wanting to know the exact same thing...
Old Feb 28, 2005 | 10:14 PM
RockyJSquirrel's Avatar
It will be louder. You will lose power and low-end torque. Smarter and wealthier people will look down their noses at you and pity you for intentionally ruining your truck.
Old Mar 1, 2005 | 02:48 AM
Green_98's Avatar
war eagle
Hell yea--mom was an Auburn graduate back in the 70's
Exactly what I did on my 98 4.6--sounds really good, better than any muffler setup in my opinion. Didnt notice any power/torque loss either, if anything a very slight gain in gas milage. Plus it was cheap to have the muffler cut out and would be cheap to have another welded in
Old Mar 1, 2005 | 07:30 AM
RebelYell's Avatar
I cut off the factory muffler and had a piece of pipe put in it's place. (Single straight pipe, factory pipe size).
Sounded GREAT until you got up high in RPM's, then it sounded crappy. I wound up putting a 21" glasspack on. Sounds good, but not loud enough for me.
I noticed no performance difference, and a little better fuel mileage.
I am looking to do a dual exhaust setup now.
Old Mar 1, 2005 | 10:21 AM
max mitchell's Avatar
EXACTLY !
Cut dem sumbitches off !
Old Mar 1, 2005 | 08:54 PM
kbldawg's Avatar
^^^^ ROFLMAO!!!
Old Mar 1, 2005 | 10:09 PM
RebelYell's Avatar
LOL...That's great!.
However... I lost nothing and gained abut 1 mpg after cutting out the factory muffler. Just sounded terrrible at high RPM's.
Going with true duals Thursday.
Old Mar 3, 2005 | 12:29 AM
Green_98's Avatar
my 4.6 sounds pretty dam good above 4500 with straight pipes....nice roar but the best sound is about half throttle, the nice rumble....id try it and see, i doubt youll be dissapointed
Old Mar 3, 2005 | 09:40 PM
RebelYell's Avatar
I had true duals ran on my truck this morning.
Cut the pipes just after the cats and ran two 2.25" pipes, with 2 18" glasspacks. Exiting just behind each rear tire at a 45 degree angle.
Only $200 and looks like good work (first time I have ever used this muffler shop) time will tell.
So far I like the sound, but have only driven it about 60 miles since the work was done. I can say that, without a doubt, the truck has lost no low-end at all, and has definitely gained a tad from 1800 RPM and higher. I haven't towed a trailer yet, so I am anxious to see how that goes also. And any mileage comparisons will have to wait until I get used to the roar out the back. It sounds too good to try to be easy on the throttle right now!
I give the deal a big at this early stage.
Old Apr 2, 2005 | 11:27 AM
laidbacksouther's Avatar
Lightbulb
I had the stock muffler cut off and a second pipe ran out the back and the truck sounds great....I've been pleased. No noticeable gain or loss in hp or mpg just an awesome sound at any rpm.....really cool when firing it up.
Old Apr 2, 2005 | 02:35 PM
texaspyro21's Avatar
What about cutting open a stock muffler and taking a lot of the junk out inside? wouldnt you get better sound and have enough backpressure to keep the low end torque from dropping some?
Old Apr 2, 2005 | 03:08 PM
Eyescream's Avatar
I'm fairly new to trucks, but I've been working on various vehicles for a long time. If my experience with watching friends hollow out their catalytic converters is any indication, then hollowing out your mufflers will make your exhaust produce this ****ty, awful rattling sound all the time, and the harder you pusht he motor the worse it will sound. You might get more power, but in my opinion it's not worth it. Your mileage may vary.
Old Apr 2, 2005 | 03:17 PM
Faster150's Avatar
get a dynamax muffler their loud as all get out....
Old Apr 4, 2005 | 04:05 PM
domgar's Avatar
I cut the muffler open and removed the baffle tubes in one of the chambers (03 f150 harley has two chambers with DI/DO), welded it back up with the weld on the top so it looks stock from underneath. sounds deep and not to loud but better than stock
