HELP! - tricks to remove stock muffler?
Old Jun 4, 2001 | 10:27 PM
s.haun's Avatar
Post HELP! - tricks to remove stock muffler?
UPS showed up with my new borla exhaust today. I soaked everything in WD40, unbolted the clamp, cut and removed the tailpipe, got all the little rubber hangers off, the muffler turns a little, but I can't get it to slip off! The clamp seems to have crimped the two together. I wasted about an hour and had to call it a night. Surely someone knows a trick?
Old Jun 4, 2001 | 10:34 PM
Jim A's Avatar
Post
s.haun,
What I did was use my dremel to carefully cut two slits in the muffler pipe without cutting into the tube from the cats. Then I used a chisel and hammer to spread the slits and peel the pipe back to remove the muffler section. It was a major Bit@h and if I were to do it again I would pay a shop to do it. Your truck looks great hope you enjoy the Borla when you get it installed my brother in-law has the dual side exit in front of the wheel it looks and sounds great
99 XLT SC Flareside Sport, Oxford White, 4.6l, 275/60/17, 3.55LS, 4 wheel discs/ABS, Ford bedliner, Downey Tonneau, K&N, Flowmaster II Dual out rear catback, Clear corners. Street Scene grille painted black and Stillen Storm air dam with lights (unpainted for now).
[This message has been edited by Jim A (edited 06-04-2001).]
Old Jun 5, 2001 | 10:51 AM
JOHNNY BONDS's Avatar
Post
Go to your local auto parts store and get a muffler chisel. It is designed to cut only the outer pipe without damage to the inner pipe.
98 Nascar Edition, Superchip, Airaid, Flowmaster 70 series, bedliner, in bed tool box, Profile bug deflector and window vents, Class III receiver hitch.
Old Jun 5, 2001 | 02:25 PM
Jag's Avatar
Jag
Post
I used a hacksaw and made an angle cut about 1/3 of the way around the outside pipe. If you're careful, you won't damage the inner pipe. I then used a BFH to hit the muffler while someone else pushed and rotated the muffler.
BTW, which system did you buy?
1998 F-150 XLT Supercab 4X4
  • Silver Metallic Clearcoat
  • Med. graphite cloth interior
  • 4.6 l. V-8
  • Off Road Package
  • 3.55 Reg. Axle
  • Am/FM/CD factory radio
  • Captains Chairs
  • Borla Split Rear Dual Exhaust
  • Bedliner
  • Hood deflector
  • Ventshades
  • Trenz billet #5 low clearance antenna
  • Torsion bars cranked 3 turns
Old Jun 5, 2001 | 06:59 PM
max mitchell's Avatar
Cool
I used the angle cut, it worked like a charm in 5 minutes. Twisted it right by using the exhaust tip/exit as a handle.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 4.10LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Pirelli Scorpion Zero 275/60/16s, Mobil 1, K&N oil filter.
Old Jun 5, 2001 | 08:56 PM
s.haun's Avatar
Post
Jag/Max,what do you mean by angle cut?
Jag, dual tip single side exit.
Old Jun 5, 2001 | 09:31 PM
Cool
The exhaust pipe runs horizontally, the slip joint is a 90 degree, you cut a 45 degree slash on the exterior overlapping pipe with a hacksaw. __\__
Old Jun 6, 2001 | 08:10 PM
s.haun's Avatar
Post
Thanks to all that helped. B'gerFH was all that was really needed... Now all I have to do is drive it.
