does it matter that one exhaust tip is lower than the other?
my left exhaust tip is lower than my right one i just think its really annoying to look at tell me what u think, (if u cant tell by the pic its about an inch lower)
Do you have the Flowmaster Force II exhaust kit?
I do and I had the same problem with the pipes.
I installed it myself and then later took it to a shop and had them cut a little bit of the exhaust pipe on the driver side and then re-weld the pipe. Shortening it up made it line up a little bit better with the tip on the passenger side. It still isn't perfect, but it looks considerably better than it did.
You bent something off road. Excellent! ann that is missing are the Off Road dimples. The creases/bumps in the cab where the bed touches it at extreeme angles when twisting the frame.
Go under the truck and try bending the hanger to linge it back up.
JMC
JMC
