Advice from anyone that runs with no mufflers
My current system has the factory Y feeding a Flow 50 Delta si/do that dumps out the back with 4" tips. I would like to eliminate the muffler and retain everyting from there back.
Should I add a Y pipe in place of the muffler, or should I cut the factory Y and run 2 separate pipes back to connect past where the muffler was? I want the big block sound without the popping and cracking noises the exhaust makes when the throttle is on the way back down. Anybody know what I'm talking about?
97 F-150 4.6 4x4
K&N Fipk
Dual Flowmaster 50
Superchip
32" BFG's
Toyota stuck to bumper
97 F-150 4.6 4x4
K&N Fipk
Dual Flowmaster 50
Superchip
32" BFG's
cut out all y pipes on your truck run 2 1/2 or 21/4 pipe and what ever tip you want you will get exactly what you want....trust me i did
jj
97 4x4 ORP 4.6l
flareside supercab
rear blackouts
westin step bars(black)
side window louvers
lund shadow wiper cowel
true duals 5 in tips
k&n F.I.P.K
17in' wheels 265/70 Bridgestone dueler A/T's
ventshades
tinted windows 5%
[IMG]Dscf0024.jpg[/IMG]
www.f150world.com/southernthunder
jj
97 4x4 ORP 4.6l
flareside supercab
rear blackouts
side window louvers
k&n F.I.P.K
ventshades
tinted windows 5%
hey guys,
i run straight pipes on my 4.6 and let me give you some advice. carefully watch the pipe size. i went with 2 1/2" the first time and lost lots of low-end. i went back and changed to 2 1/4", felt stock again. not that my truck is anything super strong. i just can't afford to lose much torque as i am usually hooked up to something, or have a decent load in the back. i cut the muffler off, added in a y-pipe and ran duals straight out the back. sounds great and does not pop..hope this helps, Rich.
-1999 F-150 4X4 XLT SC
-4.6, auto
-3.55LS
-Westin chrome nerf bars
-dual straight pipes
-goodyear mt/r 265/75/16
-hikerdadrich@aol.com
-4.6, auto
-3.55LS
i used 2 1/4 all the way back to my tips then we had to up it to 2 1/2 bout 4 inches then up to 3 inches so we could fit my tips!
97 4x4 ORP 4.6l
flareside supercab
rear blackouts
side window louvers
k&n F.I.P.K
ventshades
tinted windows 5%
97 4x4 ORP 4.6l
flareside supercab
rear blackouts
side window louvers
k&n F.I.P.K
ventshades
tinted windows 5%
