High Flow Cats??? >>>>
Old Oct 9, 2004 | 03:47 AM
TYSTYX's Avatar
which high flow cats does everyone recommend for my 2000 4.6 ?? Can I also get a part number please??
thanks.
Old Oct 9, 2004 | 11:55 PM
Green_98's Avatar
best place to get them is on ebay. Magnaflow has them for around 55 bucks a piece shipped, pretty good deal. For the 4.6 and 5.4, i believe the 2.5" inlet/outlet size will fit.
Old Oct 10, 2004 | 09:37 PM
F150Flare's Avatar
I would recommend the hi flow cats to anyone, good power and sound increase. Mangaflow,eastern catalytic, just do a search my man.
Old Oct 16, 2004 | 11:16 PM
Jlevy's Avatar
Question High Flow Cats - Error Code on 02 sensor
I took off the 4 standards and replaced them with the two high flow cats. Now I've got an error code that is showing up in my check engine light. My bro-inlaw is a manager at an Advance Auto and ran a error code check on mine. He says it's in the 02 sensors after the CATS. He says there is a 02 bypass sensor that can be plugged in to replace the standard 02 sensors that will correct this problem.
When I reprogram my HyperTech back to normal or just re-do it for power the error goes away for a few hours. Anyone got any ideas here????
thanks
JL
Old Oct 21, 2004 | 01:38 PM
Jordan not Mike's Avatar
Can you just have sensor bungs welded-in behind the cats? It would likely be cheaper than any other solution.
I had my setup installed with the sensors in the factory locations, so I got no code...
Old Oct 21, 2004 | 04:46 PM
Jlevy's Avatar
Question
What are sensor bungs? Where do I get them and how do they work?
thanks,
JL
Old Oct 22, 2004 | 06:44 PM
The bung is the threaded hole that the sensor screws into. Any muffler shop will have them, shouldn't cost more that a couple of buck each. You weld the bung into the pipe, then screw the sensor into the bung.
Old Oct 22, 2004 | 09:11 PM
98SurplusExpy's Avatar
I have a 5.4L .... but this is the response I got back from a MagnaFlow Tech on the topic ...
Thanks for your contact. Yes, there are indeed 2 cats on each side. However, it is not legal to do a 2-for-1 switch. I don't know if you are concerned about that or not, but you may have trouble finding a shop willing to do that for you. As long as you are outside CA, the proper universal cats to use are our 91000-series up front (probably 91076), and the 94000-series in back (probably 94006). All of these are high-flow. Check out the link below to find a dealer in your area who can sell you the parts and install them for you. Thanks for your interest in Magnaflow.
http://www.magnaflow.com/03dealer.htm
Danny Christian
Performance Sales Specialist
Magnaflow Performance Exhaust/Car Sound
800-990-0905 ext.1143
