Got An Exhaust! Did I Gain Power?
Old Jan 8, 2000 | 06:34 PM
BMW325's Avatar
Exclamation Got An Exhaust! Did I Gain Power?
Ok I went ahead and bit the bullet and bought an exhaust for my 93 F-150 5.0 (302). I got:
A Flo-Pro performance muffler, it has one inlet and two outlets. I kept my factory catalytic convertor on. So I ran one piece of pipe from the catalytic convertor into the new muffler and then two pieces of pipe out of the muffler and put some nice chrome tips on. I used 2.25" tube all the way around.
The truck is not really loud it just has a much deeper tone to the exahaust not to mention how much better it looks then the old stock exhaust. I am really happy with it. But it seems that it didn't make any difference at all in my horsepower.
The truck is stock except for a K&N drop-in and a Superchip.
1: So should I have gained some power from this? If so around how much HP?
2: Did I loose any torque with this setup over the stock system?
Thanks!
1993 Ford F-150
Kustom Kreations Package
2WD, 5.0 (302), AOD, 3.55
K&N Drop In, Superchip & Pirelli Scorpion Zeros!
Eclipse CD Player, Eclipse 8-CD Changer, Eclipse Amp, Clarion front speakers, 8" Boston Acoustics Subwoofer
Old Jan 8, 2000 | 10:01 PM
Pastmaster's Avatar
Post
OH YES! you surely did! I am not sure if a muffler setup like yours would be much different than mine, but in any case you'll notice a difference. Just give it time.
I really don't know about hp ratings though. I know that you can gain 4-7 hp by removing the cat.
Toydestroyer1@yahoo.com
1993 F-150 302/e4od/355 Limited slip. dual exhuast w/o mufflers,2 1/4" pipes with Echo Tips, headers, accel plugs/wires(8.6mm)/rotor/cap, hypertech powermodule, 4 degree advance,5% dark tint. Alpine cd player and Pioneer speakers.
NEWLY ADDED:Blaster Coil,MSd 6A Ignition, TPS Mod,hopefully roller rockers in the future!!
1989 F-150 XLT 4x4 302/aod true duals with turbo mufflers, 30X9.50" wild country tires, 3:55 gears
Old Jan 10, 2000 | 04:38 PM
BMW325's Avatar
Thumbs up
Well after a little "informal" testing. I do believe I have gained some power. I know this is not a good way of testing power gains but before the exhaust in a level surface the truck would barley "squeal" the right rear tire now it will squeal for every bit of two seconds. Also when doing 65mph on the interstate and I kick it down to pass someone it seems to pick up speed a lot quicker and it wants to keep on going.
I figure that after my Superchip, K&N and Exhaust I've probably gained about 28hp at the flywheel. So maybe about 20 RWHP. That seems pretty good.
Now I need to figure out what to do next. I hate to remove the catalytic convertor because if i ever sell the truck it will be a lot harder to sell. We don't have emissions or anything here but, like everywhere else we are supposed to leave the catalytic convertor on. I wonder if a cop got down and checked to see if I had one, if I would get in trouble or not?
Hmmmmmm, I could also do headers but they are a lot of $$$$ and a lot of time. Plus a lot of hassle tightning up the bolts every 25k miles and putting in new gaskets. I just don't know what to do next.
Old Jan 10, 2000 | 11:41 PM
Pastmaster's Avatar
Post
BMW: I would honestly think you gained more than 28 hp with your mods. Jeez I know I gained more. This summer, I plan on removing some of the innerds of my cat. (YA, I know its illegal.) or running true duals with 2 convertors. I really love my headers, I have only tightened once in almost a year, and they were worth the money. I have cracked manifolds on my old truck, so I'm planning for another set.
I finally got the ignition on, or should I say had it put on, and I have noticed slight more throttle responce, will tell more n time.
Other VERY cheap upgrades, you may think about is, a TPS mod, and advancing your timing. It is a noticeable difference, and its free, providing the right tools.
Old Jan 11, 2000 | 07:21 AM
BMW325's Avatar
Thumbs up
TPS mod? Thats throttle position sensor. Correct? Never heard of modifying that for free how do I do it?
Old Jan 11, 2000 | 02:40 PM
Pastmaster's Avatar
Post
correct, Tps is the Throttle Position Sensor, it is located underneath the Throttle housing, it has several wires.
Check this out, you'll need a voltmeter, and I would have someone who is familiar with engines. I have a friend who is a retired Ford mechanic, so he gives me all the details. And there are some performance engine builders among us, who can give details, like side gapping and etc.
https://www.f150online.com/f150board...ML/000781.html
Advancing the timing. I still don't know if a chip does anything to the timing, but I advanced mine 4 degrees, the computer brings it to about 17. Everyone knows how to do this, and its very simple to do on older v-8's like ours.
