Y pipe
Old Oct 28, 1999 | 11:50 AM
cujet's Avatar
Post Y pipe
I am going to try a real y pipe with smooth flowing 2.5 inch pipes into a 3 inch pipe. Has anyone done this? I have headers and a gibson single exh. I have used my g tech to document that there is really no change in the performance of the truck and I am now starting to look for the other restrictions in the system. I know the intake horn on the airfilter is a restrictive part of the intake as it is only 49mm in dia. and the y pipe is a poor design.
what do you guys think?
Chris
98 SC 4.6L stepside, Gibson headers, Gibson single exhaust, superchip, Intake mods, Piaa's, high end audio stuff.
[This message has been edited by cujet (edited 10-31-1999).]
Old Oct 29, 1999 | 01:54 PM
JOHNNY BONDS's Avatar
Post
Chris, I've thought about doing the same thing and flowmaster makes a Y pipe 2.5 in and 3 out, it is about $35.00 but it looks like it will take a lot of cutting, bending and welding to get it in. Also, the book says for off road use only????? several months ago someone else was talking about this but I don't know who it was and I don't recall seeing any posts on results. Do it and let us know.
98 Nascar Edition, Superchip, Airaid, Flowmaster 70 series, bedliner, in bed tool box, Profile bug deflector and window vents, Class III receiver hitch.
Old Oct 29, 1999 | 08:23 PM
JHerron's Avatar
Cool
Hey Chris,
My muffler guy is going to cut into my existing Y when he puts on the Flowmaster 70 and 3" piping for me. The stock Y is all made of 2½" pipe, so he'll leave the 2½" pipes coming out of the cats, cut the Y at it's largest point, and weld in a 3" pipe from there to the muffler (and 3" mandrel bent tubing from the muffer out). I know the inside of the Y might get a little ugly from the weld, but having two 2½" pipes come together into one 3" will not result in any backpressure increase (believe it or not, the flow through two 2½" pipes is the same as the flow through one 3" pipe).
Anyway, sorry for rambling and sorry I don't know of a pre-fabbed Y that will fit your needs. If you can wait, I'll post results when I get it installed.
best regards,
P.S. I had a modified 3" induction tube for the airbox, but recently took it off and put the stock back on. I may go back, but other than quicker throttle response there was no benefit. I am still trying to figure out why I have a bit of a rough idle and I thought maybe it was from the airbox mod, but it wasn't. Oh well...
'99 F-250 LD 5.4L SC XLT 2WD 3.73LS in White/Silver (w/ EVERYTHING 'cept leather and engine block heater) -- added: SnugTop Hi-Liner & carpet kit, Donnelly electrochromatic/compass mirror, K&N filter, SuperWhite 9007 bulbs, IAS shocks, Mobil 1, more to come... (Flowmaster 70 cat-back exhaust is on order, Westin side bars, electric fan, Superchip, and silver fender/wheel flares are next)
http://hometown.aol.com/jimorama/myh...ollection.html
[This message has been edited by JHerron (edited 10-29-1999).]
Old Oct 31, 1999 | 08:16 PM
cujet's Avatar
Post
Thanks for the reply guys. Please keep me posted and when I have time I will do the mod and let you guys know how it works.
Chris
Old Nov 1, 1999 | 01:39 AM
V10 man's Avatar
Post
cujet,
When I had my 97 F150, 4.6L, I dualed it out by cutting out the "Y". The stock tubing size was 2 1/2". Where the driver's side pipe is welded onto the passenger side is where most of the restriction is. First the tubing was reduced, I'd guess and say to 2 1/4", then, the hole in the passenger side pipe is about 2" in dia. Now, if this doesn't but some backpressure on the left bank I don't know what will.
