Gibson single 3" back pressure test
Old Apr 9, 1999 | 10:32 AM
cujet's Avatar
A note to all: I just tested the new single 3" muffler flow rates in both directions. Very interesting, the guys at gibson told me to install the muffler with the open end of the louvers toward the engine,,,THAT WOULD BE A MISTAKE!!!! The muffler has excessive back pressure in that direction while only very mild restriction in the other direction. About 10 times more restriction in the wrong direction!!! I tested the muffler using a high volume air source and a calibrated pressure gauge accurate to 1/1000th of a psi. If you install the muffler with the open end of the louvers toward the engine you will have much more back pressure than stock.
Chris
Old Apr 9, 1999 | 07:50 PM
Gman's Avatar
cujet:
What about numbers? How about dyno graphs of gibson vs. stock hp? This would be very informative information.
Old Apr 9, 1999 | 08:39 PM
cujet's Avatar
Sorry I dont have it installed yet, however when I install the exhaust I am also installing headers and a much improved Y pipe. As for the dyno results I have a G-TECH for the raw numbers, 0-60 1/4 mile and trap speed etc... As soon as I'm done I will make a trip to superchips dyno to tweak my superchip. I promise to post the numbers.
ps I really like my 98 F150 flareside supercab.
Old Jun 13, 1999 | 05:48 PM
The Pathfinder's Avatar
Cujet:
Which way did you end up installing the muffler??
I am guessing not that way Gibson instructed, did you discuss this with Gibson? I read your other post that seems to show the Gibson to loose some HP, is this because you installed the muff backwards??
Sorry for all the questions but I plan to install next weekend (receiving truck on friday) and the Gibson instructions talk about the muff as it has a front and a back but this is not marked on the can. So it would seem best guess.
This is the only tread I found on the subject. -- Strange.
Thanks!!
On Order - 1999 F-150 4x4 XLT Ext Cab Flairside(Black w/dark graphite) Sport Package,5.4,auto,3.55LS,skid plates,captains chairs,cd changer,keyless entry,tow package,bed liner,& tonneau cover. Aftermarket Mods Ordered - Airaid FIPK (from F-150 Online Store),Gibson Side Swept Single,Smittybilt Modular Black Textured Nerfs,Deflecta Shield Magnum Deflector,Ventvisors,& Code Alarm SureGuard40 Security Sys (integrates w/keyless entry)
Old Jun 13, 1999 | 10:17 PM
cujet's Avatar
I did install it with the louvers facing away from the engine. I plan on trying it the other direction also but this summer is a busy time in my line of work so I may not have the time soon. By the way, the 6 cats make more than enough back pressure for the engine. I really do not think More back pressure is necessary.
Also an update on my trucks performance, I did loose some low end and gain some top end with my mods. the truck makes more HP in the upper RPM than ever. However the loss of low end keeps the truck in the same range of 0-60 and 1/4 mile as before the mods.
98 SC 4.6L stepside, Gibson headers, Gibson single exhaust, superchip, Intake mods, Piaa's, high end audio stuff.
Old Jun 13, 1999 | 10:40 PM
GMC305's Avatar
Cujet,
Umm, umm, 6 cats!?!? Assume your talking about catalytic convertors, but 6 of 'em?!?!
Old Jun 14, 1999 | 10:25 AM
94F150's Avatar
cujet,
The numbers I got from Gibson for the Swept Side 3" single for a 94 F150 w/ 5.8L was 11HP and 23 Ft-Lbs of torque increase. I've also read that lack of back pressure can cause losses on the low-end while allowing increases on the high end. What are your thoughts on this? Do you think their recommended direction was to keep the necessary back pressure for the mentioned torque gains?
94 F-150 XLT SC 4x4 5.8L Auto 3.55 Towing pkg
K&N, Gibson Swept Side cat-back (3" single), Superchip,
Custom paint, Fender flares/running boards, bed rails,
Oak console with 2 beverage cooler/heaters and 4-quart cooler,
Oak interior trim, Body Gard bedliner, Lund bug shield,
Drawtite hitch,
14,000 original miles
Old Jun 14, 1999 | 08:40 PM
cujet's Avatar
Yes 6, 1 light off cat on each side and one 2 element cat on each side. The 2 element one is the lower one. My back pressure measurement of the cats shows more than 5 psi back pressure. I really think this is more than enough!
The earlier ford trucks had more restrictive exhaust than the later "97" and on ones. This is probably why gibson can claim a real performance gain on those trucks. the 4.6l engine is really very well set up from the factory and seem to have less hp to gain by the simple mods. Ford improved the head design on the newer mustang and gained quite a bit of hp. And they are still using exhaust manifolds!
Might be that the older trucks gain hp through out the powerband with the gibson.
Chris
Old Jun 16, 1999 | 07:44 PM
FYI an update on this, I finally got a chance to call Gibson, and Bill in the technical dept told me to install the muff with the open end of the louvers towards the rear (yes the way the cujet suggests). Thats what I know.
And no I didnot get the truck yet (it's still on a train somewhere) all I have to say about that is #@*&!
Old Jun 16, 1999 | 09:02 PM
Dunbarton's Avatar
Cheese'd,
When did you order it?
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The Z-71 Eater!
Wedgewood & Denim "Blue Lightning" SuperChipped, Airaid FIPK
Man, I got it all!
Old Jun 17, 1999 | 12:49 AM
Ordered it first week of May, was told 4 to 6 so I really wasn't expecting it. Then the sales guy called last monday and said it was over in the holding yard and he was going over to get it. Guess what -- not there. Anyway I'm sure it will come in soon. It was just such a let down after the call got my hopes up.
Old Jun 20, 1999 | 10:34 AM
Dunbarton's Avatar
Chris,
Have you ever done any back pressure tests actually on the truck while it is in full street setup? Isn't there a test that can be done through the O2 sensor or at the end of the muffler or cat converter?
I would like to see something like this done as I have a Gibson single cat-back next on my list of mods and have been watching your testing with interest.
Man, I got it all!
Old Jun 20, 1999 | 01:40 PM
Ford man's Avatar
Banned
this post intentionally left blank
[This message has been edited by Ford man (edited 11-14-1999).]
Old Jun 24, 1999 | 12:47 AM
LuvTheC's Avatar
I'm really confused now. I paid someone to install mine. How do I know if it is installed correctly? Hopefully, without taking it apart.
Old Jun 24, 1999 | 02:16 PM
Ford man's Avatar
Banned
