stock aint loud enough
Old Jun 28, 2004 | 12:18 AM
Patriottruck's Avatar
Exclamation stock aint loud enough
I need a louder truck. i need to know what will make my truck loud! i can't stand listening to the quite 4.6L engine. i will spend up to 400 on a good exhaust system that will increase sound and power, but mostly i want an agressive sound that will not just last during acceleration. Please Help.
Thanks, Cory
1998 F150
4.6L V8 XLT 4X4
EXT.CAB FLARESIDE :
Old Jun 28, 2004 | 01:10 AM
84fordman's Avatar
i can tell ya that true duals with no cats and no mufflers and 2.5 inch pipe and 4 inch tipes it is loud as hell and you will be very noticalbe out in your town with it
p.s it is illegal as hell were im from and i still do it
Old Jun 28, 2004 | 02:04 PM
max mitchell's Avatar
Have a "cut-out" welded to your exhaust system before your muffler. They cut a hole in the side of the pipe then weld a few inches of pipe to that with a cap held on with 2 bolts. Run it open or bolt it closed for legal matters. It shouldn't cost one tenth of your budget.
Old Jun 28, 2004 | 07:34 PM
Green_98's Avatar
cut out your factory muffler have straight pipe welded in, or if you want dual tailpipes installed, install a Y pipe. Your muffler guy can make one easy. Will make a really good throaty sound that will turn heads easily and shouldnt cost over 200 (no spending 60+ dollars for a dam muffler!)
If thats not loud enough, start on your 4 cat converters!!
Old Jun 30, 2004 | 08:14 PM
If you look at the "muffle removal" forum, Way Fast Witey says that you lose a little power and that having a 4.6 with no muffler and a straight pipe (in my case a y pipe) is still not very loud. I know it's an opinion but is it REALLY LOUD with a y pipe installed and no muffler, or is it only a little louder? And when he says "loses power" is he full of crap? Check the forum and get back to me.
Thanks, Cory
Old Jul 4, 2004 | 02:57 PM
way fast witey's Avatar
you'll probably not gain as much power just takin the muffler off,you'll still gain over stock,that's what i meant by that.and i have a 5.4 so i don't know how a 4.6 reacts to just takin off the muffler,y-in to dual outlets.you might as well try though,if you don't like it you can always go back and throw on a muffler.you only lose a little low end when you take off andything causing backpressure,when you lose more backpressure you gain top end performance though.if you don't like it without a muffler i suggest a flowmaster 40 if you want a good aggresive tone
