x-pipe vs. h-pipe
Old Mar 30, 2004 | 01:07 AM
mustngpny50's Avatar
x-pipe vs. h-pipe
I was wondering if someone knows and/or could explain the difference in the h and x pipe.(other than one looks like an H and one looks like an X)
Basically what do you gain from each. Is one more for sound or is there a performance difference with one vs. the other. I have an H on my mustang and plain old true dual on my truck. I was wondering if there would be any benefit to put in an X on my truck.
Also, if there are any other threads on this subject please let me know
Thanks,
mustngpny50
Old Mar 30, 2004 | 07:00 PM
max mitchell's Avatar
I take it that you already know that both improve horsepower and sound by balancing the backpressure in both banks of your engine. The difference is in flow and design. The X is a updated version that has better flow characteristics which in turn is simply more efficient in all aspects.
Old Mar 31, 2004 | 12:30 PM
suds5.4's Avatar
What ^ said.
Old Apr 27, 2004 | 11:32 AM
fmexplorer's Avatar
The h and x pipes will give you different torque and hp - you need to choose based on what your goals are. I had an x-pipe on my '94 GT and it drove my mechanic nuts. The h-pipe would give better high-end horsepower and torque (trans. - better for racing) while the x-pipe was better on the low end (better for pulling). Put the pipe in that meets your needs.
Jon
Old Apr 27, 2004 | 05:50 PM
Toolman00's Avatar
I've heard the opposite of what ^^^ said. Simply put, a crossover would make a little more power than without. I'm sure it helps improve the sound too.
Old Apr 28, 2004 | 09:28 PM
FleasF-150eatshondas's Avatar
It gives you a more linear torque curve throughout most of the driving range (i.e. from 2000 to about 4500). GREAT torque. I went from a SI/DO glasspack to a full new exhaust using 2 high-flow cats, new crossover pipe, and an X-pipe... WOW what a difference.
-Flea
