Need some help with a noise plz!
Here's the deal.
Got a noise that sounds like its the heat shield under the passenger side front seat of a 2001 Expedition.
But here's what I need your help with:
Description:
* externally loud vibration noise
* ONLY at idle
* ONLY when in gear with the brake applied
* wife says she can feel it under her floorboard
I crawled up under the truck (mind you it was still hot, so I didnt go poking around the hot exhaust system too much), but the noise sounds like its coming from closer towards the engine compartment.
Anyone run into this and have a clue?
I know I need to go digging in the daylight, but jsut thought I would ask.
Thanks in advance.
Greg
Description:
* ONLY at idle
Thanks in advance.
Greg
I agree. Same thing happened on my 92 F150. Exactly what you described. My fix: I wrapped steel wire around the entire heatshield and cat. It worked but I don't expect you to do the same on an Expo. My F150 was a POS and falling apart.
