True Duals on 4.2 liter v6
Old Jan 1, 2004 | 09:44 PM
69 girl's Avatar
I put on true duals on my truck with no x /or h pipe ,the factory cats are still on ,with two flowmasters ,it sounds good but alot of poeple keep telling me i've lost alot of horse power and tourqe. Is this true?
Old Jan 1, 2004 | 11:31 PM
Bartak1's Avatar
You may have lost alittle, not alot.
If you used the right sized pipe you are fine.
All you loose is acceleration.
I put true duals on my truck and i lost alittle bottom end, but i used 2.5 inch pipe, and for my engine they say to use 2.25. I dont really care though, it still goes.
What size pipe did you use?
Old Jan 1, 2004 | 11:32 PM
69 girl's Avatar
pipe size
2.25
Old Jan 2, 2004 | 12:02 AM
Bartak1's Avatar
Too big, you should have 2 inch(im pretty sure) But thats puny and looks bad. Did it feel like you lost power? If you want to get it back put like a flowmaster 30 or 70 series on. Wont sound as good, but it will give you more back pressure.
Old Jan 2, 2004 | 09:36 AM
69 girl's Avatar
true duals
ive lost alot of the get up and go around 2nd and third
Old Jan 4, 2004 | 01:38 AM
WHITE4.2F150's Avatar
maybe an H or x-pipe might be need...im sure it would help
Old Jan 4, 2004 | 09:17 AM
openclasspro's Avatar
x-pipe
use next size down- 2" for your x-pipe- this will help get your velocity back up
Old Jan 4, 2004 | 09:43 AM
69 girl's Avatar
true duals
i ended up changpng to a x-flow magnaflow muffler ,#12598 i do believe ,the truck is a lot quicker then it was with the flows on it and it sounds alot better ,quit at idle, but loud enough when u step on the gas i love it .
Old Jan 10, 2004 | 02:23 AM
sk8inrj1's Avatar
Note to poepl who think that and H or X pipe will solve the back flow problem. There is NO need to pu these pipes because the firing order of the 4.2 v6 is even. and a v8 is odd, thats why you need one for a v8. so on your V6's the exhaust flows are already balanced.
Old Jan 10, 2004 | 07:53 AM
Lightbulb flow
what if the one of the cylinders is weaker???????????????
Old Jan 10, 2004 | 09:23 PM
Bartak1's Avatar
True, a H pipe wont do anything, but a X pipe will get alittlle power back if you lost some because of the smaller area casued by the cross.
Old Jan 15, 2004 | 10:13 PM
whtthunder's Avatar
what if i were to run true duals 2.50 pipes and no mufflers on my 4.2 would i lose some power because i just put on an airaid intake and a helix power t-body spacer and will do my underdrive pulleys when i do my exhaust if i dont do headers.
Old Feb 1, 2004 | 04:08 PM
babbad's Avatar
straight pipe
I got straight pipe on my its loud and it has more power. I'm going to take off the cats soon as I eliminators for the Co2 sensors.
Old Feb 1, 2004 | 04:14 PM
beechkid's Avatar
25 Year Member
Cool
I really hate to say this, but......you really don't have true duel exhaust. What you have is a y-pipe at the end of the head pipes that has two separate pipes with mufflers running back. It's great from a looks standpoint and not too shabby on the performance end. To have real duel exhaust, you would have to purchase additional catylitic coverters for the second pipe.....and guess what, no muffler shop will do it without you signing a wavior because the Federal & state smog laws just don't allow such a modification...Yup, you'll fail the visual inspection at the smog test. I invite anyone who would like to see real duel exhaust to come by and take a peek at my 65 shelby...
Old Feb 1, 2004 | 04:52 PM
not necessarily so
if they undid the y pipe from each headpipe and ran a pipe to a muffler from each bank -why isn't this true duals?
