flames out of the exhaust
here's a question that ou don't see every day. a friend of mine wants to make flames come out of his exhaust tips (1979 F-250, highly modified 300ci engine, 4 barrel holley carb, no cats, no mufflers, straight pipes). we've already tried with no success. has anyone in here done something like this? heres the setup we already tried:
-wire from the battery to a toggle switch
-wire from the toggle switch to a coil
-from the coil to a spark plug drilled into one of the exhaust pipes
-carb running rich so theres unburnt fuel in the exhaust
we got it to work a few times, but it would only light for a sec or two, then the flame would die and not light again. we are sure theres plenty of fuel going out the exhaust, and the plugs are not getting fouled or anything. we think that its a spark problem, but we cannot be sure. if you pull out the spark plugs from the pipes, you can see that the plugs are lighting. has anyone tried something like this? any suggestions are appreciated, because we are running out of ideas, thanks...
My understanding on this subject is that you need to get a propane tank and rig in the propane similar to how you have done the spark plug. Then your need to be able to regulate the flow of propane to the amount of exhaust gases so that you have enough propane to produce a flame that will stay lit once it has been egnited by the spark plug. LEt us know how it works
Here ya go guys...have fun, and BE CAREFUL!!!
http://www.hotrodsetc.net/menu.html
-AR
2001 F-150 XLT 4x4 Off-Road, SuperCab, Flareside, Black[*] 4.6L Triton V8 HPI[*] 5 Speed / 3:55 Reg. Axle[*] Keyless[*] Premium Audio CD
Mods:[*] K&N Intake (Chopped Airbox)[*] Removed Elbow Silencer[*] 3" Cat-Back (No Muffler, Turn-Down)[*] Cranked Torsion Bars[*] APC XENON PLASMA Super Whites[*] '01 "L" Taillights[*] Bugshield[*] Bedliner[*] Ventshades[*] Removed Mudflaps[*] "Light Argent" 4x4 Off-Road Decals
Audio:[*] Clarion 6675[*] Rockford Fosgate 5x7's[*] Rockford Fosgate G360A2 Punch Amp[*] JL 12W3-D2 (Ported)[*]Viper 500ESP Alarm
Build Date: 8/23/00 (Kansas City Plant)
-AR
<font face="Verdana, Arial" size="2">Originally posted by Jag:
Hmmmmmmmmmmmmmmmm.......
Fuel, heat, oxygen. Seems like you have plenty of the first two. Where is your friend's spark plug located in the exhaust?</font>
I'd probably put the plugs closer to the end of the exhaust pipes that way oxygen will be readily available. Just a thought.
1997 F-150 XLT 4x2 SC 4.6L
Flowmaster 40 Series Delta Flow with 3.5"x22" Chrome Slach Cut Tips
Kicker 8" Subwoofer
200 Watt Amp
http://www.F150online.com/offroadguy
Being Installed This Week:
-6" ProComp Pro-Ride Lift
-35" ProComp AT Tires
-American Racing Baja 16x8 Wheels
Future Mods:
-4.56 Gears
-3" PA Body Lift
-Stull Billet Grille
-Clear Corner Lenses
-Euro Taillights
Kicker 8" Subwoofer
200 Watt Amp
Future Mods:
-4.56 Gears
-3" PA Body Lift
-Euro Taillights
Ive heard that you need to rev the engine up and cut the ignition to the engine and keep your foot on the gas and let it "freewheel" and light up your plugs in the pipes. Seen it on TV
1998 150 SC, Lariat, 5.4, Black with a little silver, 4X4, Stock at this time.
Oh dear god no!!!! don't use propane!!! You have an excellent chance of becoming a Fire Ball (I'm a fire captain)
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Did this with a friends '54 Merc back in HS with the help of an old street rodder who was doing it in the 50's. The plugs were on the end of the pipe and he drilled sone small holes upstream of the system to "tune the mixture". We got a constant 4' flame at WOT.
A friend of mine did this to his 83 Chevy. He first started my cuting the Cats off. I am not sure what else he did, but it looked awesome.
My FORD F-150
The Basics [*]2001 XLT[*]Extended Cab[*]Flareside [*]Toreador Red[*]4.6 Liter[*]V8
What makes it sit so high?[*]3" PA Body Lift[*]16x8 American Eagle 589 Series Wheels [*]305/70/16 Goodyear Wrangler A/T-S Tires
What makes it sound so good?[*]Dual Exhaust (Y-PIPE)[*]No Muffler [*]4" Chrome Tips
What makes it look so good?[*]Vent Shades[*]Bugflector[*]AVS Blackout Headlight Covers
What's inside the bed?[*]Rhino Sprayed-In Bedliner[*]Dual 3 Foot CB Antennas
What keeps me hidden?[*]20% Window Tint (Front 2 side windows)[*]-5% Back Window Tint[*]11" 7% Sun Band (Windshield)
[New Pictures Coming Soon]
FORD TRUCKS: "Tougher than a two dollar steak!"
My FORD F-150
