which flowmaster, 40 or 50 series for a 4.6 manual
i have a 4.6 manual. i want a muffler that sounds tuff , but not to loud. i want the idle to sounds tuff and when i step on it or rev it up to sound tuff and turn heads? anyones opinion would help.
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
I have a 4.6 5spd and just put in the 40 series True Dual system. All I can tell you is that I love them. They are quite loud when you step on it, and for the first time, it actually sounds the way a truck should at idle. The dudes at the shop where I put them in said that it sounded more like a 5.4 than a 4.6. When I puch it, it turns heads. Mileage has improved. The down side is that I did not put an 'H' (or 'X' pipe) on the system, and I think I've lost some on the low end, but picked it up again once I'm moving (like on the highway). So low end is less, but more horses seems about right. BUT, on the highway, the drone in the cab can be annoying when I'm on a longer trip (shorter highway trips I like the sound) Keep in mind also, that true duals seem to be louder than the SI/DO setups, but are also considerably more expensive.
Hope this helps you out.
Black 98 F150-XL, 2WD, 4.6L Slappin Windsor Triton, 5spd.,
RegCab, Short WB, 3.08 rear, Air, Rear Slider, FM40 True Duals
Triton V8 Badges, Duraliner Bedliner, K&N, Ziebart, Castrol Syntec
HAWK Plus Bedcap, profile+ wrap-around bug deflector,
Blazer Neon-Blue projector fogs, custom look'n door cracks
Tinting: #4 RearCab & Bedcap Windows, #2 Cabside Windows
My Site
[This message has been edited by defacto (edited 06-12-2001).]
My Site
defacto, what is a true dual exhaust. what is the difference between that and the regular $60 flowmaster muffle that you can buy, because all i was going to do was buy the muffler and cut my old one off and put the new one on, just a single exhuast, not dual. i was going to do that later down the rode. buy all the pipe and do it all myself. can you help me out witha ll this, the differences. thanks
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
I got the si/do Flowmaster deltaflow 50 put on my 1999 v6 today. 2 1/2 in 2 1/4 out with 18" tips out the back. You can tell it is there while idling by the rumble but it sounds great when you stomp on it. Its loud enough to turn heads but not get complaints from the neighbors or wake the kids when I leave for work at 5am. My wife loves the sound also which is a big plus. I don't think I lost any power in the low end, I might of even gained a little. There is a gain of high end power, and that great popping sound when you let off the gas.
4RDPWR:
It's pretty simple really; what they do is cut off the pipes before the factory 'y' pipe, thus avoiding a 'bottle neck' into one pipe. My understanding is that this opens up the airflow, more than on a SI/DO setup, due to the lack of the bottle neck through the 'y' pipe. Some say this messes up the backpressure, and hence, the loss of the low end torque, but the cats do most of that work. All you need to do to remedy the loss of the low end is to make sure an 'H' pipe is installed between the 2 pipes (which I stupidly
didn't do)to even out the pressure. I hope this helps, and makes sense.
My Site
[This message has been edited by defacto (edited 06-13-2001).]
didn't do)to even out the pressure. I hope this helps, and makes sense. ------------------
My Site
what is all this low end stuff. will anything change if i just cut my old muffler off and put a new flowmaster on. thats all i planned on doing, and leaving it just single exhaust. thanks
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
Future mods:
lift spindles
flip chip
exhaust
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
Future mods:
lift spindles
flip chip
exhaust
Nope, what you want won't change a thing; just the sound (which won't be that big of a difference anyway.)
The 'low end stuff' is the result of the loss of back pressure, or uneven pressure associated with adding on a system that is too free flowing. It is debatable though, whether or not this happens anyway; the cats are supposed to take care of this, and sometimes I'd swear that mine has, then other times I'd swear it hasn't lost some off the low end.
My Site
My Site
Nothing sounds better than just a piece of straight pipe
. I've tryed everything from Flowmaster to Xcelerator.
My FORD F-150
The Basics [*]2001 XLT[*]Extended Cab[*]Flareside [*]Toreador Red[*]4.6 Liter[*]V8
What makes it sit so high?[*]3" PA Body Lift[*]16x8 American Eagle 589 Series Wheels [*]305/70/16 Goodyear Wrangler A/T-S Tires
What makes it sound so good?[*]Dual Exhaust (Y-PIPE)[*]No Muffler [*]4" Chrome Tips
What makes it look so good?[*]Vent Shades[*]Bugflector[*]AVS Blackout Headlight Covers
What's inside the bed?[*]Rhino Sprayed-In Bedliner[*]Dual 3 Foot CB Antennas
What keeps me hidden?[*]20% Window Tint (Front 2 side windows)[*]-5% Back Window Tint[*]11" 7% Sun Band (Windshield)
[New Pictures Coming Soon]
FORD TRUCKS: "Tougher than a two dollar steak!"
. I've tryed everything from Flowmaster to Xcelerator.------------------
My FORD F-150
