Tailpipe stained black
These trucks all run rich to be on the safe side. I used to work at a place with 5 late model f-150's and they all had the black tailpipe. I think it is actually worse now with the chip and catback, but nothing to be alarmed about.
Howie's Effie
Amazon Green 2000 F150 XLT 5.4L 4x4 ORP Supercab Flareside
Captains Chairs, Electronic Shift, Rear Slider, Keyless Entry, Cab Steps, 3.55 L/S
Mods: Superchip, WMS Velocity Tube, Flowmaster Force II, Scorpion Spray in Liner, fogs + hibeams (thanks FedExPilot)
Howie's Effie
According to the Haynes manual I got it says black soot in the tail pipe is a indication that the truck may need a tune-up. IMO I think a little soot in the tailpipe of any truck is pretty normal and nothing to worry about. I have seen pratically brand new truck's with soooty tailpipe's.
97 Ford F150 XLT 4wd 4.6L auto, Std cab/Long bed 2 tone royal blue w tan bottom, PW,PL, and PM, captian chairs w/arm rests
Current Mods
K&N Filter
Xact Plug Wires- 8mm
Ventshade side window deflectors,read window deflector, bug guard, headlight and taillight blackouts
custom hand painted Ford emblems on door jamb guards and under hood on plastic intake cover
plastic mud guards
custom 4x4 off road graphics
Ford hitch cover and license plate frame
Custom carpet liner (protects factory carpet)
Slyvania Cool Blue Headlight and fog lamp bulbs
Pioneer 6 disc changer
Whistler 1650 radar detector
oh yeah, one custom dent and scratch from a deer the night before deer season
Current Mods
K&N Filter
plastic mud guards
I noticed my tailpipe is stained black around the tip of the tailpipe. At first I thought it was because my engine running too lean due to my having a superchip and Granatelli MAF. I removed the MAF and replaced it with stock but then noticed my neighbor's Supercrew had the same charcoal residue. Is this normal for 5.4L engine or is it an indication of a problem?
2001 F150 SuperCrew Lariat, 5.4L, Black and Gold
60/40 Front Seat, Sliding Rear Window, Side Steps, 6 Disc CD Changer, 3.55 Limited Slip, Class III Trailer Group
Line-X Spray-in Liner
Retrax Roll Top Cover
Granatelli MAF
Bell Tech 2" Drop Shackles
Superchip
K&N Air Filter
Mods to come:
Corsa or Gibson Exhaust, Front Air Dam w/ Fogs, Cervini Hood
Granatelli MAF
Superchip
K&N Air Filter
Mods to come:
SuperCrewzer- It's normal for that year and engine, before and after the chip.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Thanks everyone! I feel much better. I am hoping to do either the Corsa, Ravin or Gibson exhaust this week. After I run it for a while I'll reinstall the Granatelli MAF and see what happens.
Howies_effie - Where did you get your WMS Velocity Tube? I've searched the web but can't find any info.
Max Mitchell - What is the Outwears prefilter?
Granatelli MAF
Superchip
K&N Air Filter
Mods to come:
Granatelli MAF
Superchip
K&N Air Filter
Mods to come:
Supercrewzer - the WMS Velocity Tube was my first mod. Put it on at 5000 miles - it is an economical choice compared to the K&N or AirRaid but it was a less-than-flawless install - the lines entering the tube near the throttle body didn't quite line up and required a small amount of 'adjustment.' It is a good product for a good price, all things considered. You might consider making your own from a piece of 3" steel tube (like Neal 'the HP freak' has done). Good luck!
www.wmsracing.com/wmsweb/f150pkg.html
Howie's Effie
Howie's Effie
