Stock exhaust question
Sometimes, especially when the engine is warm, I hear a ticking sound coming from under me. I thought it was an exhaust leak - so i went under the truck and found two places where Ford connected two pieces of piping together using a clamp without actually welding the two pieces together.
Is this a likely place where my exhaust would be leaking?
And, are these areas supposed to be welded, or left with just a clamp??
My theory: I think that when the exhaust pipes get hot, they slightly change shape due to the heat and cause a leak here. I also see water around these areas sometimes.
Thank you, Stephen
2000 F-150 XL, V6, 5-speed
[This message has been edited by hades281 (edited 01-20-2001).]
Thank you, Stephen
The water is a normal thing. The leak or sound is also pretty normal, I would bet you have no leaks!!
Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC.....
ORP & Tow Package Complete Lariat Option Package
{APPEARANCE}
GTS Projector Beam /Carbon Fiber Headlight Covers
AVS Tail Lights Slots
Door Sill Protectors
Flareside tail lights wired to work upper & lower lenses together
Owens Fiberglass Step Boards
Custom Tinted Windows
Ford 2-Piece Bra
Lighted Ford Logo in Grill
20" Chrome Exhaust Tips
A.R.E Bed Cover Lid
Pendaliner Inner Tail Gate Protector
Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection
Lariat #1 Plate under glass on Front Bumper
Custom made Ford Red Window Decals
Blue Tinted Rear Lic. Plate Protector
Ford Lited Hitch Receiver Cover that works off brakes lights
Heavy Duty Bed Mat
Red reflectors above Rear Bumper
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Platinum 3 Spark Plugs
K&N Air Filter W/ modified stock MAF side air box
Outerwears Blue Pre-Filter Cover
Tornado Air Man.
Perma-Cool Oil Filter Relocation Kit
Motorcraft Racing Oil Filter FL-1HP
Fumoto Oil Drain Valve F-106
Dual Exhaust System W/Stock Muffler
NAPA Ceramix Carbon Ceramic Premuim Brake Pads(Front)
Goodyear Wrangler A/TS Tires
55 Watt Halogen(replacement) Reverse Lights
Pilot 55 watt Halogen (add-on) Reverse Lights on Hitch under truck
Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs
Pilot Bright Whites headlite bulb replacements 65/55 watts
Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay
A.R.E Cover wired W/interior(dome) light wired to a mounted door jam switch thats wired to hood light
SurgeGuard by Calterm
{AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 2 Stock Speakers(back)
2 Pioneer TS-A6865 3- Ways(front)
Black Felted Inner Front Door Speaker openings All Speakers Dynomat Lined
Trenz Billet #3 Antenna
{SECURITY}
Ford Total Security System W/ Motion Alarm All on factory Key Fob
Ford Warning Decals on Windows
A.R.E Cover & Hood also wired to Alarm System Hitch Pin locking system
This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana".
........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
Future Mod.`s.......
Soon to have Flareside Rear Step Bumper re-plated (Triple Chrome Plated)
[This message has been edited by LARIAT1 (edited 01-25-2001).]
Lariat#1
{APPEARANCE}
Ford 2-Piece Bra
A.R.E Bed Cover Lid
Heavy Duty Bed Mat
{PERFORMANCE}
4.6L WINDSOR
Auto Trans
3.55 LS
4-Wheel ABS
Tornado Air Man.
{SECURITY}
