Any Programming Issues Changing The Exhaust After The Manifolds???
Old Feb 22, 2003 | 09:27 AM
KeithG's Avatar
2002, Offroad, 5.4, ATI 12# Boost (fuel upgrades and custom tuning).
I'm keeping the stock manifolds. If I go with high flow cats and let's say SI/DO system, are there any programming issues that need tweaking?
Old Mar 1, 2003 | 11:01 AM
OLDGRAY's Avatar
exhaust
Keith; just disconnect the Battery for about 10 mins.
Old Mar 1, 2003 | 06:10 PM
Orlin's Avatar
...just disconnect the Battery...
Does this mean that I should've disconnected my battery after all the changes I've made? After the Superchip (which was installed while the batt was disconnected) I've added a K+N Gen II, a Gibson cat-back, and coil & wire upgrades. I am just about to get the chip reburned because detonation is a problem (in the warm weather) if I run less than Sunoco 94 or add octane booster to 93 fuel. Is there a possibility that this could be fixed with a disconnection? I think I'll try!
Old Mar 11, 2003 | 01:49 PM
OLDGRAY's Avatar
chip
Orlin; when you bought the chip didnt it or the inst. mention hi-test gas?? If you dont buy a flip chip,almost nothing will stop the pinging....except hi-test. I dont think a battery disconnect will do anything for You. If you dont need the power,get rid of the chip...I hope this helps,I know its a pain in the wallet but its one or the other..Good luck OLDGRAY
