Flowmaster.....
Old Nov 26, 2000 | 03:04 PM
EXCURS10N's Avatar
Question Flowmaster.....
I wanted to a muffler for my Excursion, I was looking at the 70 Series Flowmaster, because its pretty quiet - the wife has to drive it too! Anyone use this muffler? Also what is the diamiter inlet/outlet for the V-10 Excusion?
B.T.W. - Should i get a full cat-back system? I know that the EXPY doesn't gain really any HP from exhaust, and was wondering if this was true for the Excursion? Whats a good semi quiet cat back sys?
2000 Black Excursion
4WD XLT V10
-Volant Cold Air Intake
Old Nov 27, 2000 | 09:26 AM
LaserNAV's Avatar
Exclamation
EXCURS10N
I don’t know all the answers to your questions but if I were to guess you have 2.5 inch Diameter pipes like everyone else. (you would have to measure to be sure) 70 series would be nice and quiet with a slight rumble. You can go to the Flomaster web site where they have charts on the sound levels. http://www.flowmastermufflers.com/fmtest/DOCS/SET.html
In my opinion true Dules will give you the most horse power increase and is probable necessary for your heavy breathing V10, I think Flowmaster makes a 70 series that has DI/DO. This way you would not need an “H” pipe to scavenge gas. The duel exhaust can be accomplished by cutting your “Y” pipe down the middle Therefore splitting it into two separate exhaust systems. Check out “ULTIMATE EXHAUST SYSTEM” on this board.
2000 Navigator. Laser Red, Every option. , (DOHC) cams-32 valve Intech (Jaguar design), Cross Induction Intake Manifold, SIX (6) Bolt Mains, K&N FIPK , Superchip, True Duel Flowmaster 50 series. 2X SISO , vented out each side. Rear air deflector, Bug deflector, PIAA, headlights (SUPERWHITE)
Looking at Hitting 400 Hp without a blower. Using in addition, headers (If possible)
(Waiting for JBA to develope Headers)
“91” F150 4X4 Shorty “Ultimate Off Road Edition” Borge Warner T18 4 speed, Traction Lock Front and Rear Differentials., Smitty Built Duel Tube Roll Bar, Moog Super Off Road Coil Springs, Factory 2” Lift Rancho RS 9000 Shocks , Stock Front “QUAD SETUP” 33x12.5 (B.F. Goodrich) Mud Terrain Warn Winch Combo Bush Bar with Warn XD9000I Winch. Full Factory Skid Plates. 302 Long Block, K&N FIPK JBA Chrome Headers, Custom Catback using Flowmaster Muffler, Duel out side behind rear wheel.
Old Nov 27, 2000 | 05:33 PM
JOHNNY BONDS's Avatar
Thumbs up
I have been running the 70 series for a little over a year and am very pleased with it. I just have the 4.6 so I did muffler only and actually could tell a small improvement in performance. I don't know what size the original system on the Excusion is, but I would go at least to a 3" single. The sound at idle and cruise is very close to stock and there is no drone. You can tell it isn't stock only when you get on it.
98 Nascar Edition, Superchip, Airaid, Flowmaster 70 series, bedliner, in bed tool box, Profile bug deflector and window vents, Class III receiver hitch.
