Aftermarket Exhaust Hangers
Old Oct 25, 2000 | 11:50 PM
TheClear55's Avatar
Post Aftermarket Exhaust Hangers
Just had the Ravin Z-55 exhaust installed a few weeks ago at Midas, and recently noticed some rattling noises coming from the exhaust tips against the bumper. I have dual 3.5" tips out the back, and it seemed the left one was a bit too loose. So I took it back to Midas and they basically just bent the pipe with a crow bar (actually a really long wrench) and it seemed to do the trick. I guess I am a little concerned if that was typical protocal, and if the pipes are supposed to vibrate, and by how much?
The left one still feels a little loose, compared to the right one... should I take it back again?
Matt Watkins
RedClear55@yahoo.com
Black '99 SC: just came off the lease, goodies coming soon...
My Truck Page
Old Oct 26, 2000 | 01:31 AM
bomber's Avatar
Banned
Post
i kinda had the same problem. when i got my flowmaster intalled with 3.5" tips. after about 3 weeks i heard a rattling and inded up my pass. side tip was bouncing . i took it back to the shop they but on a new nut and then tack welded them on so the would not bounce loose.
Old Oct 26, 2000 | 10:36 AM
LaserNAV's Avatar
Exclamation
I know if I had this situation I would keep taking it back until I was completely satisfied. (NO RATTLES). I am sure you paid good money for their professional services you should expect a professional job (NO RATTLES BANGS OR CLATTERS). As far as bending you pipe to fit with a wrench.. Well I am not a mechanic but this seems like a cheesy way of fixing it.
2000 Navigator. Laser Red, Every option. ,FIPK, Superchip, Rear air deflector, Bug deflector, PIAA headlights (SUPERWHITE)
Old Oct 26, 2000 | 04:35 PM
max mitchell's Avatar
Cool
Metal hangers can be bent; pipe, that's another story. You are ok with some vibration, that is normal, but too much (maybe 1/2" or more) is not good.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar,
Rancho RS9000s.
