Questions on True Duals
bburk,
Nope, they're not telling you the truth.
1999 F150 4x4, wedgewood blue, 5.4l auto, Manick brush guard, Duraliner, KC Hilites, surf rod holders, tinted windows, K&N air filter without airbox, Velocity air intake tube, Midas Performance muffler with dual pipes, toolbox, Uniden CB with whip and now, enjoying a new reprieve on life with a 2000 series 5.4L (swapped engine due to Piston Slap).
They told me the same thing when I was shopping for exhausts, but it is not true. You can put true duals on your F150. However, it could cause you to lose too much back pressure. That is why I opted for the cat-back.
'97 F150 4x4 Off-Road Extended Cab Lariat Flareside white/tan, tan leather, 4.6, 3.55
Duraliner bedliner, Husky floormats, Custom seatcovers (I only cover the leather when I'm really dirty, though), Premier single-lid toolbox
Gibson 2.5" split-rear exit cat-back exhaust, K&N Air Filter
Many more modifications to come
I have a '99 F150 5.4L and am wanting to put true dual exhaust on it. I live in Dallas and have been calling around for prices and they tell me that you cannot put true dual exhaust on the new F150. From all of the post here I thought you can.. Are they telling me the truth??
bburk,
No they're lying! Most muffler shops nowadays order bolt-on products that are prebent with hardware and everything just like we can order over mailorder, only they get it cheaper. Thus, they don't have to learn how to actually bend, measure, fab hangers etc. for a (true) custom dual exhaust system. I had the same trouble, but I work about 45 miles away from where I live and I found a muffler shop over there with a fella that knew his sh_t! He installed the true duals, I watched him measure, cut, bend and mount every piece on my truck. He was a butthole, but he did an awesome job on the exhaust. Don't give up, you'll find someone that still knows enough to be able to do it for you.
'97 Ford SC 4X4 XLT Off Road pkg., 4.6,A/OD, 3:55, premium sound w/CD chg, Black clct,towing pkg., hvy duty elec. pkg., Bridestone dueler AT's, line X, Flowmaster true duals, chip, K&N air filter, smittybilt stainless nerf bars
while it is true that you can install the dual exhaust system on a vehicle you might be in trouble for a couple of reasons. There will always be plenty of back pressure for the engine to run so for someone to say that you lose power but putting dual exhaust systems on a vehicle is just not true. What will cause you problems is when this time to smog test the vehicle. You see federal law prohibits removing a catalytic converter that is not damage and if the vehicle has less than 50,000 mi. on it or is not five years old it must be replaced by the factory. The second problem you may run into during the smog test is you must have the same number of catalytic converters installed in the approximate same location as the factory. Here in California they are very strict. A friend of mine didn't believe me and almost had his vehicle impounded because of that.
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
beechkid-
Check under your truck. There is no need to alter or remove any of the emissions components. I'm not sure they would be OK in CA, but in most states, there is no problem with "true" duals.
Also, you CAN lose some low-rpm power if your exhaust is too free-flowing. Myself and others can attest to that from personal experience.
Neal
1997 4x4 Expedition- 4.6L, true dual exhaust w/glass-packs, K&N air filter, SuperChip, airbox mods, Edelbrock shocks, 285/75R16 BFG ATs, Optima "T-Bone" wheels, 4.10 gears, Auburn LS, Clarion In-dash CD player, Smitty Bilt push bars and nerf bars!!
2000 4x2 F150 XLT Reg. Cab LWB- 5.4L, Tow Pkg, 3.55LS, CD player,Remote Keyless Entry, Sliding back glass, Special Appearance Pkg.
http://members.visualcities.com/NoMo
Neal
If you run true duals, make sure you put in a balance pipenear the front. It will help with the back pressure issue.
I also had the same problem. i went to one place and they said they could do it no problem and another place said on F-150 you couldnt do it because the O2 sensor is on the Y- pipe? which one is true
'98 XLT 4.2L STX Billet Grill and insert
The O2 sensors... there are 4 of them... are not in the Y-pipe. The configuration they are describing was for pre '97 model F150s.
There is no reason to mess with the cats. The pipes don't "Y" until after them, so true duals are a cat-back mod.
The "H" pipe is an excellent recommendation too.
1997 4x4 Expedition- 4.6L, true dual exhaust w/glass-packs, K&N air filter, SuperChip, airbox mods, Edelbrock shocks, 285/75R16 BFG ATs, 2000 "XLT" wheels, 4.10 gears, Auburn LS, Clarion In-dash CD player, Smitty Bilt push bars and nerf bars.
2000 4x2 F150 XLT Reg. Cab LWB- 5.4L, Tow Pkg, 3.55LS, CD player,Remote Keyless Entry, Sliding back glass, Special Appearance Pkg., tinted windows, Line-X bedliner, and Prime #155 wheels.
head up man, they are defintely lying to u...i have a 97 F150 that has a true dual...i even managed to get them to make it look like the new lightnings side exhaust...it really looks good...email me if you need any other help...
Brandon Warford
97 Red F150 4x4 Sport
big mudders, 3" lift and lots-o-goodies
Brandon Warford
Nomo is right. And a balance tube is a good idea, especially when adding a supercharger.
What is described here is not a "bolt on". I am only aware of one bolt on true dual kit and it is made by Borla. I will need to verify that though.
'98 4.6 5-speed
BRING US YOUR TUNDRA!
Where we started.
After a facelift.
Latest MOD!
F-150online Photo Album
trixters-playground@excite.com
Truckin' Magazine!
[This message has been edited by crash1 (edited 05-08-2000).]
'98 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
Truckin' Magazine!
bburk,
I live in Garland and I got a pretty decent rate on my Flowmaster at AAA Muffler in downtown Garland. You can put a dual system on the V8 but its not recomended on the V6. Stay away from places like Merlin Muffler and Pronto they overcharge. Call all of the AAA Muffler shops around Garland because they are independently owned. Keep calling and good luck.
Snow white
2000 White sport
4.2l V6 5spd
K&N filter
e-mail: XLR8@f50guy.com
Superchip
Single in dual out 40 series Flomaster
As soon as i can afford it: Airaid FIPK
Snow white
2000 White sport
4.2l V6 5spd
K&N filter
Superchip
Hey Nickster,
Which Flowmaster mufflers did you install? And, do you have an "H" pipe on it? What differences did you notice? And, did you feel a noticeable loss in torque? Thanks in advance.
beechkid,
Do you have a reference to the laws you cited? I didn't know any of those. All I know is that a muffler shop guy recommended duals and said they were legal. I was thinking about installing hi-flow cats, maybe Dynomax Super Converters, but if I'm going to get nailed, I'd leave the cats alone. Thanks.
'99 XLT 5.4L 4x4 3.73, White Supercab Flareside - Grill Guard, Superchip, Gibson cat-back, K&N FIPK
beechkid,
Anyone put Magnaflows on their 5.4l? What is the opinion? It seems that most here like the Flowmasters. I don't like them and want something different, something deep sounding but little resonance in the cab. I have heard the Flowmaster 50s and they sound raspy/resonant.
