help... noisy exhaust...
Old May 30, 2000 | 07:50 PM
maggman's Avatar
Question help... noisy exhaust...
hey second post to this .... 1999 F150 triton 5.4, with 27k on clock.,.. since new has a loud metal flexing sound coming from cats,(while driving, every ten seconds) same sound as when shut off, cooling metal sound hot to cold... is this normal? has anyone had a FIX for this, dealer has clampped same with no noise reduction... Thought it was "piston slap," but told no several times... THANKS IF YOU CAN HELP..
Old May 30, 2000 | 08:51 PM
max mitchell's Avatar
Post
Mine does this only after turned off. Freaked me out when I bought it because it is the loudest I've ever heard. I've seen others ask about this, so it must be common.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
4-wheel disc/ABS,Chestnut/Parchment,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Old Jun 16, 2000 | 01:30 AM
powerlifter405's Avatar
Post
I too heard this, I picked up my truck w/ 238 miles on it. I put 200 miles on it in the 2 days i test drove it. At first it was very loud. Usu in the evenings when it was cool out side it was the loudest. W/ just 1300+ miles it seems to be non existant.
I knew what it was and it is just the metals expanding and contracting. In time they should do this less and less. Kind of like a house settling after it's built. My understanding is the first 5 years or so are the fastest and after that settling will normally cease.
Dr.(wife says i'm spoiled) Jones.
5.4L(whatpowerawaitsthee)
SC4x4.
djones01@elp.rr.com
