Exahust heatshield rattle?
I just bought a 99 f150. Just after 2k rpms there seems to be what sounds like a heatshield rattling. Is it common for the shields on the cat to rattle and make this noise? Thanks
Andrew
Andrew
There is TSB for this. What you need to do is put one to two worm clamps around each of the cat heat shields and tighten them to 60 lb-in (not very tight really).
PART NUMBER PART NAME
FOTZ-5A231-A Worm clamp (4-1/2" To 9-1/2") $4.65
W705949-S300 Worm clamp (3/4" To 4") $5.93
I suppose a local hardware store also carries them.
Whats TSB mean? Im about to go and get under my truck and figure out where this is coming from. Its driving me nuts. I tried once prodding at the cat shields, but I was all dressed up and didnt feel like getting dirty so I stopped. Hopefully Ill find it today. Thanks
ANdrew
ANdrew
Excellent, I found the culprit in about 10 minutes. A small shield on the y-pipe had a broken weld on the very end. Used a little brute force and bent that sucker away from the pipe about an inch... well. no more rattle! Hell yeah, I love it when you fix something the first try and it isnt even hard at all!
