FS/FT AudioBahn A8000T
I want to trade or MAYBE sell my audiobahn a8000t mono channel amp
Amp works awesome but its gonna be too much for my new sub and im looking at a 2 channel.
specs
http://www.sonicelectronix.com/item_...hn+A8000T.html
1600W Max, Intake Series Monoblock Amplifier
RMS Power Output:
400 watts x 1 chan. @ 4 ohms
800 watts x 1 chan. @ 2 ohms
Max Power Output: 1600 watts @ 2 ohms
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-double Sided Glass Epoxy Circuit Board
4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
Air Induction Cooling Fan
Cobalt Blue Illumination
Speaker level (high-level) inputs
Preamp outputs
Nickel-Plated Block Terminals
Optional Remote Bass Control (Audiobahn ABR100T sold separately)
Optional Remote-mount Digital Volt-meter display (Audiobahn ADM100T sold separately)
Variable Bass Boost Control: 0-18dB @ 45Hz
Variable Low-Pass Crossover: 50-120Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
Variable Subsonic Filter: 20-50Hz
THD: 0.02%
Phase Control: 0 or 180°
Input Sensitivity: 200mV-8V
Dimensions: 11-7/8"L x 11-1/16"W x 1-7/8"H
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
it easly fits under the front seats of a 97-03 f150 (manual not power)
im looking for a 2 channel amp that will run 200 watts RMS at 4 ohms for each channel.
Let me know what youve got
specs
RMS Power Output:
Preamp outputs
THD: 0.02%
