JBL Home audio equipment
Old Aug 29, 2009 | 12:29 AM
Jwool15's Avatar
I just currently moved into a new house and just upgraded all of my audio systems. These JBL units are top of the line and hardly used. One of the items is a JBL DVD600II, it is a six disk cd dvd player. It is in perfect condition. The other item up for sale is the matching JBL amplified receiver. (DCR600II) If you know anything about home audio you know that these are two top of the line receivers. I will list all of specs at the bottom for both of the receivers. They are a 10/10 cosmetically and still work like they were brand new. Serious inquires only please. I am asking $450 for the pair. Please call or text with any questions or REASONABLE offers.
DVD600
Playback Media
Audio
Coaxial Digital Audio Output
0.5V p-p/75 ohms
Frequency Response
2Hz to 22kHz, ±0.5dB (44.1kHz sampling rate)
Dynamic Range
DVD: 105dB (20-bit)
CD: 100dB
Channel Separation
90dB
Total Harmonic Distortion (MONO)
0.0035%
Signal-to-Noise Ratio
100dB
Wow and Flutter
Below measurable limits
Video
Video Formats
NTSC
Composite Video Output
1V p-p/75 ohms, sync, negative polarity
S-Video Output
Y/Luminance: 1V p-p/75 ohms, sync, negative polarity
C/Chrominance: 0.286V p-p
Component Video Output
Y: 1V p-p/75 ohms, sync, negative polarity
Pr: 0.648V p-p/75 ohms
Pb: 0.648V p-p/75 ohms
General
Unit Power Consumption
25W
Unit Dimensions
Width
17.3 inches (440mm)
Height
5.1 inches (130mm)
Depth
16.9 inches (420mm)
Unit Weight
14.4 lb (7.6kg)
DCR600
Audio
Two-Channel Stereo Mode
75W per channel continuous RMS power into 8 ohms at 0.08% THD, 100Hz to 20kHz
(frequencies below 100Hz are handled by SCS135S powered subwoofer)
Five-Channel Cinema Mode
100W per channel dynamic RMS power into 8 ohms at 0.08% THD, 100Hz to 20kHz
Input Sensitivity/Impedance
200mV/47k ohms
95dB
Surround System Adjacent Channel Separation
Analog Decoding 40dB
Dolby Digital 55dB
DTS 55dB
Frequency Response
10Hz – 100kHz (+0, –3dB)
FM Tuner
Frequency Range
87.5 – 108MHz
Usable Sensitivity
1.3µV/13.2dBf
70dB (mono)
68dB (stereo)
Distortion
0.2% (mono)
0.3% (stereo)
Stereo Separation
40dB @ 1kHz
Selectivity
±400kHz, 70dB
Image Rejection
80dB
IF Rejection
90
Tuner Output Level
500mV at 1kHz, ±75kHz Deviation
AM Tuner
Frequency Range
520 – 1710kHz
45dB
Usable Sensitivity
500µV (loop)
Distortion
0.8% (1kHz, 50% Modulation)
Selectivity
30dB at ±10kHz
Video
Video Formats
NTSC
Input Level/Impedance
1Vp-p/75 ohms
Output Level/Impedance
1Vp-p/75 ohms
Video Frequency Response
10Hz to 8MHz (–3dB)
General
72W idle, 580W maximum
Unit Dimensions
Width
17.3 inches (440mm)
Height
6.5 inches (165mm)
Depth
17.1 inches (435mm)
Unit Weight
31 lb (14.1kg)
Old Aug 30, 2009 | 07:23 PM
Jwool15's Avatar
price drop to 350 i need these gone
